Hello, I am stuck in this problem where the data acquisition of the MAX30100 pulse oximeter is being interfered by the the Oled display. I tried removing the code for the display on "updateDisplay ()" and the sensor works fine (I've figured so, using serial debugging /Serial.print(data to be displayed). But when I added the code in updateDisplay, the data acquisition of the pulse oximeter stopped.
#include <Wire.h>
#include <U8x8lib.h>
#include "MAX30100_PulseOximeter.h"
#define REPORTING_PERIOD_MS 2000 // Update display every 2 seconds
#define EMA_ALPHA 0.2 // Exponential moving average coefficient (adjust as needed)
U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(7, 6);
PulseOximeter pox;
uint32_t tsLastReport = 0;
float filteredBpm = 0.0;
float filteredSpO2 = 0.0;
void onBeatDetected() {
Serial.println("Beat");
// Exponential moving average filter
float exponentialMovingAverage(float currentValue, float previousFilteredValue, float alpha) {
return (alpha * currentValue) + ((1 - alpha) * previousFilteredValue);
void TCA9548A(uint8_t bus) {
Wire.beginTransmission(0x70); // TCA9548A address
Wire.write(1 << bus); // send byte to select bus
Wire.endTransmission();
Wire.begin();
u8x8.begin();
TCA9548A(0);
if (!pox.begin()) {
Serial.println("FAILED");
while (1);
Serial.println("Pulse oximeter initialized successfully");
pox.setIRLedCurrent(MAX30100_LED_CURR_24MA);
pox.setOnBeatDetectedCallback(onBeatDetected);
pox.update();
int rawBpm = pox.getHeartRate();
int rawSpO2 = pox.getSpO2();
// Apply EMA filtering
filteredBpm = exponentialMovingAverage(rawBpm, filteredBpm, EMA_ALPHA);
filteredSpO2 = exponentialMovingAverage(rawSpO2, filteredSpO2, EMA_ALPHA);
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
tsLastReport = millis();
updateDisplay(static_cast<int>(filteredBpm), static_cast<int>(filteredSpO2));
void updateDisplay(int Bpm, int SpO2) {
u8x8.setFont(u8x8_font_chroma48medium8_r);
u8x8.drawString(1, 2, " HEALTH ");
u8x8.drawString(1, 3, " MONITORING");
u8x8.setCursor(0, 5);
u8x8.print("BPM:");
u8x8.setCursor(7, 5);
u8x8.print(Bpm);
u8x8.print(" ");
u8x8.setCursor(0, 6);
u8x8.print("SpO2:");
u8x8.setCursor(7, 6);
u8x8.print(SpO2);
u8x8.print("% ");
u8x8.display();
