OLED display and Stepper
Hi, I'm new in Arduino... and french Canadian!
My project is to precisely rotate a disk, using a stepper motor and display the RPM on an OLED 128x64. The final usage of the project is to take astro-photos of a pulsar, when it's light is not at full brightness.
My actual problem is that: when I display something on my OLED 128x64, from 'void loop()' it cause my rotating Stepper Motor to be jerky.
As long as I let my script command in the 'void setup() ', it's all good because it only display once and it stays the same.
My second problem is that I would like to replace the ''RPM'' text by the RPM value (motorSpeed), but compil return an error: ''Compilation error: 'motorSpeed' was not declared in this scope''
¨-_-¨ Arduino, it's: Hard We Know!!!!
 Stepper Motor Control - speed control
 This program drives a unipolar or bipolar stepper motor.
 The motor is attached to digital pins 8 - 11 of the Arduino.
 A potentiometer is connected to analog input 0.
 The motor will rotate in a clockwise direction. The higher the potentiometer value,
 the faster the motor speed. Because setSpeed() sets the delay between steps,
 you may notice the motor is less responsive to changes in the sensor value at
 low speeds.
 Created 30 Nov. 2009
 Modified 28 Oct 2010
 by Tom Igoe
#include <Stepper.h>
// ¨-_-¨ OLED begin
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width,  in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// ¨-_-¨ OLED end
const int stepsPerRevolution = 200;  // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
int stepCount = 0;  // number of steps the motor has taken
// ¨-_-¨ OLED begin
// declare an SSD1306 display object connected to I2C
Adafruit_SSD1306 oled(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// ¨-_-¨ OLED end
  // nothing to do inside the setup for stepper sketch
  // ¨-_-¨OLED begin
  // initialize OLED display with address 0x3C for 128x64
  if (!oled.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    while (true);
  delay(2000);         // wait for initializing
  oled.clearDisplay(); // clear display
  oled.setTextSize(2,3);          // text size
  oled.setTextColor(WHITE);     // text color
  // ¨-_-¨ 1st line
  oled.setCursor(4, 4);        // position to display
  oled.println("Moteur RPM"); // text to display
  // ¨-_-¨ 2nd line
  oled.setCursor(40, 44);        // position to display
  oled.println("*RPM*"); // text to display
  oled.display();               // show on OLED
// ¨-_-¨ OLED end
  // read the sensor value:
  int sensorReading = analogRead(A0);
  // map it to a range from 0 to 100:
  int motorSpeed = map(sensorReading, 0, 1023, 0, 100);
  // set the motor speed:
  if (motorSpeed > 0) {
    myStepper.setSpeed(motorSpeed);
    // step 1/100 of a revolution (max=200):
    myStepper.step(stepsPerRevolution / 100);
  // ¨-_-¨ OLED begin
  // ¨-_-¨ 1st line
  // ¨-_-¨ 2nd line
  oled.println(motorSpeed); // text to display
// ¨-_-¨ OLED end
