OLED Display + Buzzer troubles
Hello,
I use a Oled Display in my project (4 pins version) like this one Display and also a little buzzer
If you take each one individually all is fine, but when you use the two together my display is freezing as soon as I use the tone function.
My buzzer is on the pin 7
The display is connect to the A4 A5 3.3V and GND pins
I use an arduino nano
The circuit is in attachment
Thank you
Is this perchance related to your other question?
Perhaps you need to read the forum instructions?
Try using a separate ground on the Arduino for the display and the buzzer and i bet it will be fine, you are getting noise from the Tones high frequency traveling back up the ground to the display.
