Oled display HANGS - DS1302 - NTC
Best forum members.
I am making an oled display in my scooter. but now after writing the code and testing it all together. I found out that the display sometimes crashes and that it only works again after it has been reset.
I use the 4 pin OLED screen (GND-VDD-SCK-SDA)
I use the DS1302 (VCC-GND-CLK-DAT-RST)
And i use a NTC for engine temprature.
Now I would like to know how it is possible that the display sometimes hangs and how I can fix it.
Could it be that the cables are too long? They are 1.5 meters long.
Below my code
thank you in advance!
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeMono9pt7b.h>
#include <Thermistor.h>
#define OLED_RESET 4 // not used / nicht genutzt bei diesem Display
Adafruit_SSD1306 display(OLED_RESET);
#include <Fonts/FreeSans9pt7b.h>
#include <virtuabotixRTC.h>
virtuabotixRTC myRTC(5, 6, 7);
Thermistor temp(0); // Weerstand aangesloten op Analoge ingang 0
const unsigned char PROGMEM skull [] = {
0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x75, 0xC3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x33, 0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0C, 0xCC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F,
  // seconds, minutes, hours, day of the week, day of the month, month, year
 // myRTC.setDS1302Time(0, 17 , 12, 3, 2, 8, 2017);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.display();
  int temperature = temp.getTemp();
  myRTC.updateTime();
  display.setFont(&FreeSans9pt7b);
display.setFont();
  display.clearDisplay();
  display.drawBitmap(0, 0, skull, 128, 64, WHITE);
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.setCursor(40, 0);
  display.println(myRTC.hours);
  display.setCursor(52, 0);
  display.println(":");
  display.setCursor(58, 0);
  display.println(myRTC.minutes);
  display.setCursor(70, 0);
  display.setCursor(75, 0);
  display.println(myRTC.seconds);
  display.setCursor(30, 16);
  display.println(temperature);
    display.setCursor(45, 16);
      display.println("C");
  display.display();
1.5 meters is long for an I2C cable. I2C is meant for communication between integrated circuit chips on the same or very near by PC board. You may be able to improve the connection my lowering the values of the pull up resistors on the SDA and SCL lines (to 1K at a minimum), using a slower transmission rate and/or shielded cable.
