I got a OLED display in a kit and it won't turn on no matter what. The wires are connect correctly and the power supply is five volts. I am using the GDA Adafruit library and the SSD1306 one. I've tried just about everything and I'm only asking for help as a last resort. Is my oled display broken or am I just doing something wrong?
Did you, perchance, see something like this when you joined up, but decided it couldn't possibly help you? Without a schematic of how you've wired it, or your code(in code tags, please), or any link to "just about everything" (which must be a web site of possible solutions, maybe?) , what exactly are we to do for you?
Before asking questions:
If your sketch was generated with AI like ChatGPT or by someone else tell us at the beginning of your post.
- Questioners know what their hardware and software looks like but the volunteers here do not. You need to fully explain what’s not working, and how it is supposed to work.
- Before asking your questions, please read all the posting guidelines, follow these guidelines when you post your questions.
Hardware
- As always, show us a good schematic of your proposed circuit. Hand drawn schematics are acceptable.
- Schematic diagrams are the universal language of electronics
- We use schematics to communicate hardware design.
- Show us several good image views of your actual wiring.
- Give WEB links to your major components.
Software
- For readability, place { and } on separate lines by themselves, place each line of code on a separate line.
- In the Arduino IDE, use Ctrl T or CMD T to format your code, then copy the complete sketch.
- Use the < CODE / > icon from the ‘posting menu’ to attach your copied sketch.
- When you follow the posting guidelines, volunteers can be more effective.
- When we have a schematic we can speak the schematic language in helping you.
- More volunteers will help when you properly post your questions.
Prove the OLED will not turn on.
Prove the wires are connected correctly.
Prove the five volts power supply is 5 volts.
What is GDA?
What program are you running to control the display? You should start with an example from you library.
