Oled display
Hello everyone
Does anyone know how can i design a sinple menu system to work with an oled display ?
it needs to use the adafuit lib SSD1306 or SH1106.
Hope someone can help or point in to the right direction... :slight_smile:
Kind regards
NP
delete post
menu do do what?
i have something for setting option values and editing multi-digit numbers.
the type of display shouldn't matter as long as it can display 2 lines of reasonable length
hello all
to0n7:
Hello,
I also try to do a menu for oled display. I have already done one but for lcd.
For the library it depends of the screen you have.
I can share you my lcd sketch if you want.
Is it a menu with pushbuttons?
The display's i have is a 1.3" oled and a 0.96" oled and an rotary encoder
gcjr:
menu do do what?
I need to design a kind of menu that has a cuple os options like
on the main screen should look something like
Menu
Menu 1
Menu 2
About
and the structure is:
  • Menu1
    -Sub 1.1
    -Sub 1.2
    -Sub 1.3
  • Menu2
    -Sub 2.1
    -Sub 2.2
    -Sub 2.3
  • About
Note: all examples i have seen online, there are big dif between LCD coding and OLED coding
see attached. code was developed on PC for esp32 using Oled. all output is thru disp() which displays 2 strings. input thru i, j, k, m keys.
PM me if interested and have questions
Menu_0330f.zip (5.54 KB)
