OLED ESP8266
I need to make a small board to allow me to cap my WEMOS D1 with an OLED. this is a tiny board and if I get a 10cm x 10 cm panel, I will wind up with about 150 of them.
Just has the OLED and some wires. I plan to put in the pull-up resistor pads, but also run a trace for to bridge. that way, one can use the internal pull-up for the I2C bus.
any suggestions ?
The I2C is on D1 and D2 and fixed at this point.
There are two versions, one has the OLED soldered to the board, the other has the OLED plug into a 4 pin header with right angle pins.
