Hello,
I am making a volume controller with an LCD and I only want to show the volume of the potmeter i am turning.
I finally got it too work but now when i turn the potmeter the lcd starts flickering.. I have been banging my head against the wall on how to fix it. if you review my code and point out mistakes I made would very much appreciate it.
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
const int numPotentiometers = 2; // Define the number of potentiometers
const int potPins[numPotentiometers] = {A0, A1}; // Define an array to store the analog input pins connected to the potentiometers
const int numReadings = 10; // Number of readings to average for the moving average
int currentIndex = 0; // Index to track the current position in the array
// Array to store the recent readings for each potentiometer
int readings[numPotentiometers][numReadings];
// Initialize serial communication for debugging
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;);
// Initialize the array of readings to zero
for (int i = 0; i < numPotentiometers; i++) {
for (int j = 0; j < numReadings; j++) {
readings[i][j] = 0;
// Read analog voltage from the pin corresponding to the current index
int rawValue = analogRead(potPins[currentIndex]);
// Perform any necessary processing on the raw value
int stableValue = rawValue >> 2;
display.clearDisplay();
// Update the array of readings for the current potentiometer
updateReadings(stableValue, currentIndex);
// Calculate the moving average for the current potentiometer
int movingAverage = calculateMovingAverage(currentIndex);
// Compare the current value with the moving average
int difference = stableValue - movingAverage;
if (abs(difference) >= 10) { // Adjust the threshold as needed
Serial.print("Potentiometer on pin ");
Serial.print(currentIndex);
Serial.print(" changed. New value: ");
Serial.println(stableValue);
drawVerticalProgressBar(stableValue, 255, SCREEN_HEIGHT);
// Move to the next potentiometer
currentIndex = (currentIndex + 1) % numPotentiometers;
display.display();
// Function to update the array of readings for the current potentiometer
void updateReadings(int value, int index) {
for (int i = 0; i < numReadings - 1; i++) {
readings[index][i] = readings[index][i + 1];
readings[index][numReadings - 1] = value;
// Function to calculate the moving average for the current potentiometer
int calculateMovingAverage(int index) {
int total = 0;
for (int i = 0; i < numReadings; i++) {
total += readings[index][i];
return total / numReadings;
void drawVerticalProgressBar(int progress, int total, int height) {
// Calculate the height of the filled portion of the progress bar
int filledHeight = map(progress, 0, total, 0, height);
// Draw the filled portion
display.fillRect(0, height - filledHeight, 10, filledHeight, WHITE);
// Draw the empty portion
display.fillRect(0, 0, 10, height - filledHeight, BLACK);
// Draw an outline around the progress bar
display.drawRect(0, 0, 10, height, WHITE);
