It works! i have included all the literal strings in F() and also fused the two cases together (dont know why i didn't it sooner) and saved some more ram
The new code is the following:
#include <Rtc_Pcf8563.h>
#include <SimpleDHT.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //(pin A5 - SCK / A4 - SDA)
Rtc_Pcf8563 rtc; //the wiring only require 5v, GND and two analog channels, A4 for SDA and A5 for SCK
#define PCF8563address 0x51
const byte pinDHT11 = 8;
SimpleDHT11 dht11(pinDHT11);
const byte red = 5;
const byte white = 6;
const byte fr = 9;
const byte green = 10;
const byte blue = 11;
const byte Fans = 3;
const byte pinPompa = 4;
const byte pinAllarm= A1;
const int z = 600; //Limit value for the water sensor
byte temperature = 0; //set the initial T & H of the DHT and write on the serial if it worked
byte humidity = 0;
int err = SimpleDHTErrSuccess;
pinMode(Fans, OUTPUT);
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(fr, OUTPUT);
pinMode(white, OUTPUT);
pinMode(pinPompa, OUTPUT);
digitalWrite(Fans, LOW);
digitalWrite(red, LOW);
digitalWrite(green, LOW);
digitalWrite(blue, LOW);
digitalWrite(fr, LOW);
digitalWrite(white, LOW);
digitalWrite(pinPompa, LOW);
Serial.begin(9600); //inizio seriale
rtc.initClock(); //start the RTC
rtc.setDate(29, 1, 3, 0, 20); //day, weekday, month, century (0-1900,1-2000), year (0-99)
rtc.setTime(02, 00, 00); //hr, min, sec
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //start the screen
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(WHITE, BLACK); //set the screen so that spaces turn black and overwrite the values (needed for cleaning rows separately
display.setCursor(0,16);
display.print("SERRUINO");
display.display();
delay(2000);
display.setTextSize(1);
display.print("LED OFF");
display.display();
//write on the serial if DHT11 worked
if ((err = dht11.read(&temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
Serial.print(F("DHT11 Failed Read")); Serial.println(err);delay(1000);
return;
//serial print all values
Serial.println("===============================");
Serial.print(F("Data: "));
Serial.println(rtc.formatDate());
Serial.print(F("Ora: "));
Serial.println(rtc.formatTime());
Serial.println(F("Valori: "));
Serial.print(F("Temperatura="));
Serial.print((int)temperature); Serial.println("*C"); //dht library already maps the values
Serial.print(F("Umidità Aria="));
Serial.print((int)humidity); Serial.println("%H");
//Display printing. 2 color oled display from 0 to 15 yellow, divided into 2 full rows at 0 and at 8, while after 16 its cyan, with rows at 16, 24, 32, 40, 48 & 56 without spaces
//print RTC values
display.setCursor(0,0);
display.print("Data: "); //print the date and hour to the screen
display.setCursor(50,0);
display.println(rtc.formatDate());
display.setCursor(0,8);
display.print("Ora: ");
display.setCursor(50,8);
display.println(rtc.formatTime());
//print DHT11 values
display.setCursor(0,26);
display.println(F("T(C):"));
display.setCursor(50,26);
display.println((int)temperature);//Stringa da visualizzare
display.setCursor(0,36); //Sposta il cursore di lato per non sovrapporre le stringhe
display.println(F("H(%):"));
display.setCursor(50,36);
display.println((int)humidity);
int value = analogRead(A0); //Read the values of the button pad
const int valuemap = map (value, 0, 440, 0, 30); /* values for a 5v input
0 40 79 113
164 193 221 247
284 306 327 347
375 392 408 423
mapped to
0 2 5 7
11 13 15 16
19 20 22 23
25 26 27 28
//each map value gets a case. pwm range between 0 and 255. set the led state and print LED state
switch (valuemap) {
case 0:
analogWrite(red, 0);
analogWrite(green, 0);
analogWrite(blue, 0);
analogWrite(fr, 0);
analogWrite(white, 0);
analogWrite(Fans, 0);
Serial.println(F("LED 0"));
display.print(" "); //these are to clean the led state row only when a new state has been set
display.println(F("LED 0"));
case 2:
analogWrite(red, 60);
analogWrite(green, 60);
analogWrite(blue, 60);
analogWrite(fr, 60);
analogWrite(white, 60);
analogWrite(Fans, 120);
Serial.println(F("LED +"));
display.print(" ");
display.println(F("LED +"));
case 5:
analogWrite(red, 120);
analogWrite(green, 120);
analogWrite(blue, 120);
analogWrite(fr, 120);
analogWrite(white, 120);
analogWrite(Fans, 190);
Serial.println(F("LED ++"));
display.print(" ");
display.println(F("LED ++"));
case 7:
analogWrite(red, 240);
analogWrite(green, 240);
analogWrite(blue, 240);
analogWrite(fr, 240);
analogWrite(white, 240);
analogWrite(Fans, 240);
Serial.println(F("LED +++"));
display.print(" ");
display.println(F("LED +++"));
case 11:
analogWrite(Fans, 60);
Serial.println(F("LED R-FR-W"));
display.print(" ");
display.println(F("LED R-FR-W"));
case 13:
analogWrite(fr, 0);
Serial.println(F("LED G-B-W"));
display.print(" ");
display.println(F("LED G-B-W"));
case 15:
digitalWrite(pinPompa, HIGH);
case 16:
//print pump & allarm values
int allarm = analogRead(pinAllarm);
if (allarm>z) {
Serial.println(F("Acqua Rilevata"));
display.setCursor(0,46);
display.println(F("Allarme:"));
display.setCursor(50,46);
display.println(F("ON"));
digitalWrite(pinPompa, LOW); //if the water sensor sense water outside the enclosure, turn the pump off
else if (allarm<z) {
Serial.println(F("Acqua Non Rilevata"));
display.println(F("OFF"));
int motore=digitalRead(pinPompa);
if (motore == HIGH) {
Serial.println(F("Pompa ON"));
display.setCursor(0,56);
display.println(F("Pompa:"));
display.setCursor(50,56);
else if (motore==LOW){
Serial.println(F("Pompa OFF"));
delay (1000); //minimum delay for DHT11 to work properly
display.display();
display.print(" "); //to clean the display, without cleaning the LED state row
display.print(" ");
display.print(" ");
display.print(" ");
display.print(" ");
display.print(" ");
I would kiss you but i'm quarantined, so have my digital thanks <3
