oled lcd 128x64 not showing anything
Hi, i am trying to run a simple code on my lcd but after uploading the code nothing is showing on the lcd screen.
it was okay at first.
I have checked with i2c scanner and the address showed up it is 0x3C.
Yes, i did uncomment #define SSD1306_128_64
here is the example code
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
// OLED display TWI address
#define OLED_ADDR 0x3C
Adafruit_SSD1306 display(-1);
#if (SSD1306_LCDHEIGHT != 64)
#error(“Height incorrect, please fix Adafruit_SSD1306.h!”);
#endif
// initialize and clear display
display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
display.clearDisplay();
display.display();
// display a pixel in each corner of the screen
display.drawPixel(0, 0, WHITE);
display.drawPixel(127, 0, WHITE);
display.drawPixel(0, 63, WHITE);
display.drawPixel(127, 63, WHITE);
// display a line of text
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(27,30);
display.print(“Hello, world!”);
// update display with all of the above graphics
display.display();
I am using nodemcu.
here is the connection
LCD NodeMCU
GND → GND
VDD → 3v3
SCL → D6
SDA → D7
Then what did you do?
it's my bad.
I used the 3v instead of 5v.
PrahastaGiri:
IMHO you should use 3.3V for a Nodemmcu.
