Here's the full sketch. I've been messing around with it quite a lot, commenting out code gradually until I can find the issue so I can fix it. Some of the functions listed are not called, including the bluetooth functions, and some variables are not used now also:
This is an example for our Monochrome OLEDs based on SSD1306 drivers
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/category/63_98
This example is for a 128x64 pixel display using I2C to communicate
3 pins are required to interface (two I2C and one reset).
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source
hardware by purchasing products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries,
with contributions from the open source community.
BSD license, check license.txt for more information
All text above, and the splash screen below must be
included in any redistribution.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <SoftwareSerial.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
SoftwareSerial mySerial(2,3);//Purple Tx / White Rx
mySerial.begin(9600);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
//Set up bluetooth device name and role etc
//initBluetooth();
//Screen 1
startupScreen();
delay(5000);
//Screen 2
versionScreen();
delay(5000);
commandScreenHeader();
delay(100);
//Screen 3 - Start to test the BT device
commandScreen("AT+NAMEalexbt2", "+NAMEalexbt2", "OK");
delay(5000);
//Screen 4
NextScreen();
delay(5000);
delay(100);
//Screen 5 - Second test
commandScreen("AT+ROLE0", "+ROLE0", "OK");
//checkSerial();
//**** Send commands to BT device
void sendCommand(const char * command) {
//String Success = "";
//Serial.print("Command send :");
//Serial.println(command);
//mySerial.println(command); //Send command to BT Device
//wait some time
//delay(100);
char reply[100];
int i = 0;
while (mySerial.available()) {
reply[i] = mySerial.read();
i += 1;
//end the string
reply[i] = '\0';
//Serial.print(reply); //Print reply to Sketch Serial Monitor
Success = reply;
//Serial.println("Reply end");
delay(50);
//commandScreen("SentCommand", "CommandVerifucation", "Success");
void initBluetooth(){
//Set Serial baud rates
//mySerial.begin(4800);
//Serial.begin(4800);
//Set up the BT accordingly
//sendCommand("AT");
sendCommand("AT+ROLE0");
sendCommand("AT+UUID0xFFE0");
sendCommand("AT+CHAR0xFFE1");
sendCommand("AT+NAMEalexbt2"); //Set the name of the Bluetooth device to alexbt2.
//This name is hard coded into the iPhone App
//sendCommand("AT+HELP");
//Delay for 3 seconds
//delay(3000);
void NextScreen() {
display.clearDisplay();
display.setTextSize(2); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0,0); // Start at top-left corner
display.println(F("NEXT......"));
display.drawLine(0, 16, 127, 16, SSD1306_WHITE);
display.display();
void versionScreen() {
display.println(F(" Alex Weir"));
display.setCursor(0,20);
display.println(F(" Bluetooth"));
display.println(F(" Tester"));
display.setTextSize(1);
display.setCursor(0,47);
display.println("");
display.println("---- Version 1.1 ----");
display.display();
//delay(5000);
void startupScreen() {
display.setTextSize(3); // Normal 1:1 pixel scale
display.setCursor(25,0); // Start at top-left corner
display.println(F("SBSS"));
display.println(F(" December"));
display.println(F(" 2024"));
display.println(F(" COPYRIGHT 2024"));
display.display();
//delay(5000);
void commandScreenHeader(){
display.setTextColor(SSD1306_WHITE, SSD1306_BLACK);
display.setCursor(3,0);
display.println("BT COMMAND");
display.display();
void commandScreen(String Cmnd, String St, String OC){
display.setCursor(0, 23);
display.println("SEND: " + Cmnd);
display.setCursor(0, 34);
display.print("SENT: " + St);
display.setCursor(0, 45);
display.print("REPLY: " + OC);
display.display();
For use with HM-10 BLE Bluetooth Module
When uploading the name seems to change. Sometimes leaves out the 2 from alexbt2
The software on the lights app accommodates this.
char c = ' ';
boolean NL = true;
boolean AWReceived = false;
String Msg = "";
String LightSequence = "";
int LightSequenceDelay = 200; //Initial delay
long randNumber = 0; //Used for Random light sequence
long randNumber2 = 0; //Used for Random light sequence
String SentCommand = "";
String CommandVerifucation = "";
void updateSerial(){
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
void TestmySerialRead(){
void checkSerial(){
if (mySerial.available()) //If BT available
//The iOS app sends the string with a # at the end of it. The string is built
//character by character (Msg) until the # is reached and then the complete message
//is received.
//Read the a character
c = mySerial.read();
if (c == '#')
//The # received so message is completed - Msg
Serial.print("FROM BLE: " + Msg);
Serial.write("\n");
//Get light sequence request received from iPhone as Msg or delay value
if(isNumeric(Msg) == true){
//Is numeric. Do whatever before Msg is set to ""
}else{
//If not numeric. Do whatever before Msg is set to ""
//Full message complete and processed, so set Msg to nothing
Msg = "";
}else{
// No # received so carry on building the string
Msg = Msg + c;
// check a string to see if it is numeric and accept Decimal point
bool isNumeric(String str) {
for (byte i = 0; str[i]; i++)
Serial.print(str[i]);
if (!isDigit(str[i])) return false;
return true;
boolean isDigit(char c) {
return (((c >= '0') && (c <= '9')));
