Oled print only 1 desimal
Hi
I want to present temp with 1 desimal
Code under gives 25.12 Celsius
display.setCursor(80, 25); display.print(myPayload.DHTtempKube);
I have tried "%.1f"
display.setCursor(80, 25); display.print("%.1f", myPayload.DHTtempKube);
but this don't compile:
Error:
ArduinoData\packages\esp32\hardware\esp32\2.0.6\cores\esp32/Print.h:91:12: note: conversion of argument 1 would be ill-formed:
Receiver_v32:193:49: error: invalid conversion from 'const char*' to 'long long unsigned int' [-fpermissive] display.setCursor(80, 45); display.print("%.1f", myPayload.pakkeNr);
Anyone who can give me a tip? Was hoping to add code per display.print line, not make an conversion up front.
M
Did you try
Hi
I mixed, flota vs int. Soultion came from you @anon56112670
correct is:
display.setCursor(80, 15); display.print(myPayload.vekt, 1);
Alternatively
display.printf("%.1f", myPayload.DHTtempKube);
However, only some types of arduino support use of .printf(), like ESP8266 & ESP32.
Other types of Arduino like Uno do not, but you can use sprintf() instead
char buffer[20];
sprintf(buffer, "%.1f", myPayload.DHTtempKube);
display.print(buffer);
An advantage of printf() and sprinf() is that you can specify a minimum field with:
display.printf("%2.1f", myPayload.DHTtempKube);
This will ensure that a space is printed before the first digit, if the value is under 10. This can help with aligning a column of numbers on your display.
You can also use
display.printf("%02.1f", myPayload.DHTtempKube);
which will print an extra 0 if the value is under 10.
