OLED random dotting; need help on how to set startup
Hello,
Fairly new to arduino but quite good with electronics. I’ve made what is basically a random number generator using an arduino nano and this OLED - https://www.amazon.co.uk/gp/product/B07FCFVXZ8/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
The circuit itself works and the arduino functions as intended but on start up the screen is filled with randomised dots until the button is pressed. Anyone know how to program a sort of start up image?
Heres the code i’ve been using ;
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <TrueRandom.h>
Adafruit_SSD1306 display(4); // create display object
const int buttonPin = 2; // the number of the button pin
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // setup the OLED
pinMode(buttonPin, INPUT); // setup button
if(digitalRead(buttonPin) == HIGH) {
delay(10);
display.fillScreen(BLACK); // erase the whole display
display.setTextSize(3);
display.setTextColor(WHITE);
int roll = TrueRandom.random(1, 21); // store the random number
if (roll < 10) {
// single character number
display.setCursor(58, 4);
display.println(roll); // write the roll
drawDie(); // draw the outline
else {
// dual character number
display.setCursor(48, 4);
display.display(); // write to display
delay(50);
void drawDie() {
display.drawRect((display.width() - 80) / 2, 0, 85, 30, WHITE);
and here is a collection of pictures. https://imgur.com/a/Cg7un5P
Cheers!
If all you want to do is clear up the random pixels, copy the code that is executed, in loop(), after the switch is pressed, to setup().
Sweet, thank you. I've done that for now. To display something such as a logo how would I go about inserting the code for it?
With a text editor.
There is not a drawLogoSomehowWithNoUserInputButBeSureTheLogoIsWhatTheUserExpects() method in the library.
I understand the text editor but needed to know what else was needed in the code for it to display, such as the whole line of code
Still stuck on this guys. Random pixels still exist and i'm unsure where to place code to cause the black screen
Do you know WHAT code to place somewhere?
If you do that in setup(), what happens? What happens if you change BLACK to GREEN or PINKPOLKADOTTED?
