Oled screen constantly refreshes
Could someone take a look at the code below That I download from RCGroups for a low ohm meter and suggest a way to rewrite to stop the screen constantly re-writing while there is a resistor under test in place. It is a real PIA .
    This is a program to use the MCP3424 A/D converter along with a Nano and OLED
    to provide a microOhmmeter function.
    This unit automatically conducts four ranges on the A/D converter and selects the proper one.
    Start date is 04/18/2019
    Complete date 04/20/2019
    Upgraded to PCB layout, complete rework of sketch program file
    Upgraded date is 07/01/2020
    Upgraded to measure test current with 0.1 Ohm resistor
    Upgraded date is 07/03/2020
    Upgraded to read over 2 OHms 08/25/2020
    Minor tweeks and a warning note
    ref Gainx1, max input voltage is 2.5 VDC for full scale ***
    ref Gainx8, max input voltage is 0.25 VDC for full scale **
 ** ref SRxxB is bit resolution, ranging from 12 to 18 bits  ***
 ** MCP 3421 has one channel input
 ** MCP 3422 has two channel inputs
 ** MCP 3424 has four channel inputs, from CH1 to Ch4
    WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING
    DO NOT DO RESISTOR TESTS WITH ONLY THE USB POWER TO THE METER!!
    THAT RESISTOR UNDER TEST REVERSES BIASES THE ARDUINO NANO 5 VOLT REGULATOR
    AND WILL BLOW THE REGULATOR.  A 6.6 VOLT POWER SUPPLY MUST BE CONNECTED
    TO THE METER ANY TIME THE USB PC PORT IS PLUGGED INTO THE ARDUINO NANO
    WHEN CONNECTING A TEST RESISTOR TO THE MICRO OHM METER.
#include <Wire.h>
#include <MCP3424.h>
#define OLED_RESET 4
#include <Adafruit_SH1106.h>
Adafruit_SH1106 display(OLED_RESET);
MCP3424 adc(PIN_FLOAT, PIN_FLOAT);
const int V_Cal = 1000;                      //1166 number is used to calibrate voltage
float R_Cal = 1.005; //  R_CAL is the calibration of the meter against a known resistor
#if (SH1106_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SH1106.h!");
#endif
float value;  //define variable
double R5_Ohm ;
float Vx_Ohm;
float Rx_Ohm;
double range1;
double range2;
double range3;
double range4;
float test_resistor;
float Ad_Cnv = 0;
int Ad_In = 0;
  analogReference(INTERNAL);
  display.begin(SH1106_SWITCHCAPVCC, 0x3C);// initialize 128/64 with the I2C addr 0x3D
  display.setTextSize(3);
  display.setTextColor(WHITE);
  display.clearDisplay();
  display.setCursor(25, 0);
  display.print("uOhm");
  display.setCursor(20, 30);
  display.print("meter");
  display.display();
void do_R5ohm()              //measure the voltage on 5 Ohm 1% resistor for calculation
  adc.creg[CH4].bits = {GAINx8, R16B, CONTINUOUS, CH4, 1 };
  ConvStatus err = adc.read(CH4, R5_Ohm);                           //Read 5 Ohm Volts
  R5_Ohm  = R5_Ohm * 10.14;         //R5_Ohm variable contains voltage drop on resistor
void do_range1()               //following routines runs variable settings on channel 3
  adc.creg[CH3].bits = {GAINx8, R18B, CONTINUOUS, CH3, 1 };
  ConvStatus err1 = adc.read(CH3, range1);                             //Read Rx Volts
  range1 = range1 * R_Cal / R5_Ohm;
void do_range2()
  adc.creg[CH3].bits = {GAINx1, R18B, CONTINUOUS, CH3, 1 };
  ConvStatus err2 = adc.read(CH3, range2); //Read Rx Volts             //Read Rx Volts
  range2 = range2 * R_Cal / R5_Ohm;
void do_range3()
  adc.creg[CH3].bits = {GAINx2, R14B, CONTINUOUS, CH3, 1 };
  ConvStatus err1 = adc.read(CH3, range3);                             //Read Rx Volts
  range3 = range3 * R_Cal / R5_Ohm;
void do_range4()
  adc.creg[CH3].bits = {GAINx1, R12B, CONTINUOUS, CH3, 1 };
  ConvStatus err1 = adc.read(CH3, range4);                             //Read Rx Volts
  range4 = range4 * R_Cal / R5_Ohm;
void do_battvolts()
  Ad_In = analogRead(7);                                        //show battery voltage
  Ad_Cnv = map(Ad_In, 0, 1023, 0, V_Cal);          //convert to actual voltage reading
  display.setCursor(50, 56);
  display.setTextSize(1);
  display.print("Batt V = ");
  display.print(Ad_Cnv / 100, 2);                            //show two decimal result
  display.setTextSize(2);
//main program starts here
  do_R5ohm();                                        //run voltage on 5 ohm resistor
  //Serial.println  (R5_Ohm, 5);
  if (R5_Ohm < 0.01)           //if A/D result is negative, no test resistor is connected
    display.setCursor(0, 20);
    display.setTextSize(4);
    display.print("OPEN!");
    display.display();
  else                                          //do the entire resistance check program
    do_range1();
    do_range2();
    do_range3();
    do_range4();
    // Serial.print ("R5 ");
    // Serial.println (R5_Ohm, DEC);               //send to USB for test_resistor purposes
    test_resistor =  max(range1, range2);        //identify the maximum resistance value
    test_resistor =  max(test_resistor, range3);
    test_resistor =  max(test_resistor, range4);
    if (test_resistor > 2.0)                             //if over 2 ohms, show over range
      display.clearDisplay();                                                //over range
      display.setCursor(0, 0);
      display.print("Over");
      display.setCursor(0, 25);
      display.print("Range");
      display.display();
      //  Serial.print ("  test_resistor=");
      //  Serial.println  (test_resistor, DEC);
      display.setCursor(80, 38);
      display.print("Ohm");                                              //show ohms value
      display.setCursor(0, 38);
      display.print(test_resistor, 4);
      display.setCursor(80, 19);
      display.print("mOhm");
      display.setCursor(0, 19);
      display.display();
      if (test_resistor * 1000 > 999)    //show milliohms result for either xxxx.xx, or xxxx
        display.print(test_resistor * 1000, 0);                       //show milliohms value
        display.display();
        display.print(test_resistor * 1000, 2);
        display.display();
      if (test_resistor * 1000000 < 999999)             //test for maximum uOhm digit display
        display.setCursor(80, 0);                              //if under 999999, display it
        display.print(test_resistor * 1000000, 0);
        do_battvolts();
        display.display();
        display.print("      ");
        display.display();
Make that else an
else if (test_resistor != last_resistor)
and track the resistor value in a new global last_resistor variable.
In this special case you also can add a delay(500); to loop() so that the display is updated only twice (or less) per second.
