OLED SPI weird behaviour
I wired this OLED SPI display 0.96 inch white spi oled display module 12864 led Sale - Banggood.com sold out-arrival notice-arrival notice to my Arduino Duemilanove (original).
I'm using the U8g2 library and there's a weird behaviour because There's a column of pixels always on and another column instead is missing. Please look at the photo.
What do you think? It could be a hardware issue? I did a mess when I soldered the pins, so it wouldn't be a surprise if I ruined it.
I also tried to rotate the display and the column is still there so I don't think this is a software issue.
darkoromanov:
I think it should be reasonably obvious that rotating the display - being a software function - does not in any way indicate it is not a software problem, which it most likely is. :astonished:
It just might help had you provided a photo - but you did not. You provided a web page instead. Let me see ...
Ah! Here it is!
