Oled text delay affects other function, any other function or proper code?
im building a 11 switches dumbpad with rotary encoder and oled display,
im about to develop more whatt i need to display to the oled but im a bit confused with the delay that i need to display into oled. so theres a main display showing idle screen text, when i update function its update a text into my oled, like play and pause, volume up or down, i want the text show in oled in certain time wich 1sec, but its also need to wait for a sec in order to make any function work.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Rotary.h>
#include <Keypad.h>
#include "HID-Project.h"
Rotary r = Rotary(14, 16); // digital Pin attached to the rotary
Adafruit_SSD1306 display(128, 64, &Wire); //  oled library
int pulse = 0;
#define SW 15
int buttonState;
unsigned long timePress = 0;
unsigned long timePressLimit = 0;
unsigned long lastButtonPress = 0;
int clicks = 0;
// kypad
const int ROW_NUM = 4; //four rows
const int COLUMN_NUM = 3; //three columns
char keys[ROW_NUM][COLUMN_NUM] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte pin_rows[ROW_NUM] = {7, 6, 5, 4}; //connect to the row pinouts of the keypad
byte pin_column[COLUMN_NUM] = {8, 9, 10}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
// kypad
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x64)
  r.begin(true);
  maindisp();
  // kypad
char key = keypad.getKey();
  if (key){
    Serial.println(key);
  switch(key){
    case '1':
      Keyboard.print('1');
    case '2':
      Keyboard.print('2');
    case '3':
      Keyboard.print('3');
    case '4':
      Keyboard.print('4');
    case '5':
      Keyboard.print('5');
     case '6':
      Keyboard.print('6');
    case '7':
      Keyboard.print('7');
    case '8':
      Keyboard.print('8');
    case '9':
      Keyboard.print('9');
    case '0':
      Keyboard.print('0');
    case '*':
      Keyboard.print('*');
// kypad
  unsigned char result = r.process();
  if (result == DIR_CCW){
Consumer.write(MEDIA_VOLUME_DOWN);
      display.clearDisplay();
      display.setCursor(5, 20);
      display.setTextColor(WHITE);
      display.setTextSize(2);
      display.setCursor(0, 20);
      display.print("vol down");
      display.display();
      maindisp();
  if (result == DIR_CW)
Consumer.write(MEDIA_VOLUME_UP);
      display.print("vol up");
      display.display();
      maindisp();
	int btnState = digitalRead(SW);
if (btnState == LOW) {
		//if 50ms have passed since last LOW pulse, it means that the
		//button has been pressed, released and pressed again
		if (millis() - lastButtonPress > 50) {
			Serial.println("play/pause");
      Consumer.write(MEDIA_PLAY_PAUSE);
 display.print("play/pause");
display.display();
 delay(100);
maindisp();
		// Remember last button press event
		lastButtonPress = millis();
delay(1);
void maindisp(){
 display.print("DUMBPAD");
  display.display();
Using delay(1000) will cause the code to stop doing anything for 1 second. If you want the code to do something during the delay() then you need to use non blocking timing. See Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
Nothing to do with timing, but why use switch/case to send the keystrokes when you can simply send the value of the key variable ?
Why not just
Keyboard.print(key);
instead of all this:
i've tried this but it seems just give me a blink (less than 500ms kinda) instead a second. sometimes it gets stuck and not do the code unless i give a little rotation. did i write it wrong?
#include <Wire.h>
#include <Rotary.h>
#include <Keypad.h>
const long period = 1000;
unsigned long previousMillis = 0;
int pulse = 0;
#define SW 15
int buttonState;
int clicks = 0;
// kypad
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
// kypad
  r.begin(true);
  // kypad
  if (key){
  switch(key){
    case '1':
    case '2':
    case '3':
    case '4':
    case '5':
     case '6':
    case '7':
    case '8':
    case '9':
    case '0':
    case '*':
// kypad
      display.display();
       if (currentMillis - previousMillis >= period){
  display.display();
  previousMillis += currentMillis;
      display.display();
  display.display();
display.display();
if (millis() - previousMillis > 1000){
  display.display();
 previousMillis = period;
delay(1);
i manage it later to make another layout so i can make it another function in some apps, my plan is to show current state layout in my oled screen.
