OLED voltmeter problem
Hi
For some reasons this program is displaying U1 2 times, i.e.
I have 3 rows.
U1
U2
U1
should be 2.
U1
U2
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
//``````Adafruit_SSD1306 display(OLED_RESET);
TwoWire Wire2 (2, I2C_FAST_MODE); // PB10, PB11
#define Wire Wire2
Adafruit_SSD1306 display(128, 32, &Wire, 4);
int  analog_value1 = 0;
int U1 = 0;
int  analog_value2 = 0;
int U2 = 0;
  // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  analog_value1 = analogRead(PA6);
  U1 = (analog_value1 * 3.3) / 4.096;
  analog_value2 = analogRead(PA7);
  U2 = (analog_value2 * 3.3) / 4.096;
  display.clearDisplay();
  drawPercentbar( 0, 0, 128, 15, analogRead(PA1) / 40);
  drawPercentbar( 0, 20, 128, 15, analogRead(PA2) / 40);
  display.display();
  delay(100);
void drawPercentbar(int x, int y, int width, int height, int progress)
  //progress = progress > 100 ? 100 : progress;
  progress = progress > 128 ? 128 : progress;
  progress = progress < 0 ? 0 : progress;
  float bar = ((float)(width - 4) / 100) * progress;
  //display.drawRect(x, y, width, height, WHITE);
  display.fillRect(x + 2, y + 2, bar , height - 4, WHITE);
  // Display progress text
  if ( height >= 10) {
    display.setCursor((width / 2) - 3, y + 5 );
    display.setTextSize(1);
    display.setTextColor(WHITE);
    if ( progress >= 50)
      display.setTextColor(BLACK, WHITE); // 'inverted' text
    display.print(U1 );
    display.setCursor((width / 2) - 3, y + 15 );
    display.print(U2);
What processor are we talking about. Can you give a schematic of the analog section? What display are you using? What interface is it?
You send x, y with these calls from loop()...
...but then do another x, y inside the function...
