I create simple sketch
#include "Num.h"
DDRB |= (1 << 5);
int b = num.getNum();
saved it to desktop. and in this folder I put two my files:
//Num.h
class Num
public:
int m_num;
int getNum() const;
Num() : m_num(0){}
Num(int);
and cpp
#include "Num.h"
inline int Num::getNum() const { return m_num; }
Num::Num(int a) { m_num = a; }
when try compile it I get undefined reference to `Num::getNum() const'
Please help me understand whats wrong?
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us.
The people who try to help with your pro…
Where is the file that contains the definition of Num::getNum()? You have the declaration in Num.h but without a file (typically Num.cpp) that contains the definition, the function is undefined.
alexblade:
but I posted code
You originally posted your incomplete code without code tags an only added them afterwards and it is still not complete
and cpp... <- after that you will find Num.cpp
UKHeliBob:
I have posted complete code , 3 files. .ino, .h, .cpp
I have read, that inline definition should be in header... and its little be not convenient ...
usually when we need to edit a class. we open the cp file. but if the inline needs to be defined in the header file, then to edit the code, we will have to open two files
is there way (somehow) to define inline func not in header ?
I challenge you to compile the sketch you have posted ie
#include "Num.h"
DDRB |= (1 << 5);
What I was getting it was the lack of a loop() function
I never wrote that you should delete loop
I didn't delete loop(). It was never there !
In your code you have this line
Where is the num object created ?
Moving the declaration from the .cpp to the .h works:
//Num.h
class Num
public:
int m_num;
inline int getNum() const {return m_num;}
Num() : m_num(0){}
Num(int);
It is not uncommon to define small functions inside the .h file and 'inline' functions tend to be small.
You can't have an 'inline' function in a separate compilation unit since the compiler has no way to inline it without seeing it.
system
Closed
September 19, 2021, 2:20pm
16
