On Arduino Mega, Ethernet messes with AnalogRead values
Hello,
I am having a problem that may be related to the Mega because I have never experienced it before. After I start the ethernet with Ethernet.begin every analog pin I read has a value in the mid 900s and I cannot read the input values.
For example,
#include <SPI.h>
#include <Ethernet.h>
static uint8_t ip[] = {
  192, 168, 1, 99 };
static uint8_t mac[] = {
  0x90, 0xA2, 0xDA, 0xAD, 0xAF, 0x77 };
  //Ethernet.begin(mac, ip);
  pinMode(A14, INPUT);
    Serial.println(analogRead(A14));
Will return a variable value based on the potentiometer I have connected to pin A14.
But
#include <SPI.h>
  192, 168, 1, 99 };
will return:
991
991
991
991
991
991
991
990
991
991
991
991
991
991
991
991
991
no matter where the pot is located.
I am sure it is something I am doing wrong. I have done this before on a smaller board and do not remember any issue like this.
Any help to point me in the right direction would be really help.
Mike
Have you tried other analog pins?
Why are you setting the digital nature of the pin when you are using it as an analog pin?
Some ethernet test code that includes reading the analog pin inputs. Note that the analog pins float with out a pot properly attached.
// zoomkat's meta refresh data frame test page 8/17/13
// use http://192.168.1.102:84 in your brouser for main page
// http://192.168.1.102:84/data static data page
// http://192.168.1.102:84/datastart meta refresh data page
// for use with W5100 based ethernet shields
// set the refresh rate to 0 for fastest update
// use STOP for single data updates
#include <SPI.h>
const int analogInPin0 = A0;
const int analogInPin1 = A1;
const int analogInPin2 = A2;
const int analogInPin3 = A3;
const int analogInPin4 = A4;
const int analogInPin5 = A5;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // arduino ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
unsigned long int x=0; //set refresh counter to 0
String readString;
void setup(){
    // disable SD SPI if memory card in the uSD slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  Serial.println(F("meta refresh data frame test 8/17/13")); // so I can keep track of what is loaded
void loop(){
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
         if (readString.length() < 100) {
          readString += c;
        //check if HTTP request has ended
        if (c == '\n') {
          //check get atring received
          Serial.println(readString);
          //output HTML data header
          //client.println("HTTP/1.1 200 OK");
          //client.println("Content-Type: text/html");
          //client.println();
          client.print(F("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"));
          //generate data page
          if(readString.indexOf("data") >0) {  //checks for "data" page
            x=x+1; //page upload counter
            client.print(F("<HTML><HEAD>"));
            //meta-refresh page every 1 seconds if "datastart" page
            if(readString.indexOf("datastart") >0) client.print(F("<meta http-equiv='refresh' content='1'>"));
            //meta-refresh 0 for fast data
            if(readString.indexOf("datafast") >0) client.print(F("<meta http-equiv='refresh' content='0'>"));
            client.print(F("<title>Zoomkat's meta-refresh test</title></head><BODY>
            client.print(F("page refresh number: "));
            client.print(x); //current refresh count
            client.print(F("
              //output the value of each analog input pin
            client.print(F("analog input0 is: "));
            client.print(analogRead(analogInPin0));
            client.print(F("
analog input1 is: "));
            client.print(analogRead(analogInPin1));
            client.print(F("
analog input2 is: "));
            client.print(analogRead(analogInPin2));
            client.print(F("
analog input3 is: "));
            client.print(analogRead(analogInPin3));
            client.print(F("
analog input4 is: "));
            client.print(analogRead(analogInPin4));
            client.print(F("
analog input5 is: "));
            client.print(analogRead(analogInPin5));
            client.print(F("
</BODY></HTML>"));
          //generate main page with iframe
            client.print(F("<HTML><HEAD><TITLE>Zoomkat's frame refresh test</TITLE></HEAD>"
            "Zoomkat's Arduino frame meta refresh test 8/17/13"
Arduino analog input data frame:
            "&nbsp;&nbsp;<a href='/datastart' target='DataBox' title=''yy''>META-REFRESH</a>"
            "&nbsp;&nbsp;&nbsp;&nbsp;<a href='/data' target='DataBox' title=''xx''>SINGLE-STOP</a>"
            "&nbsp;&nbsp;&nbsp;&nbsp;<a href='/datafast' target='DataBox' title=''zz''>FAST-DATA</a>
            "<iframe src='/data' width='350' height='250' name='DataBox'>"
            "</iframe>
</HTML>"));
          delay(1);
          //stopping client
          client.stop();
          //clearing string for next read
          readString="";
