On Board Computer for RC Helicopter
Hello, i been playing a bit with arduino and RC devices for a bit now, and i would like to work on a project for a bit more "bigger" than a car.
so i thought and on board computer could be a fun project to work on. i have an initial schematic for it already.
a few of the things i would like to do are:
  • replace the RC gyro with the one in the IMU
  • failsafe while in-flight if connection is lost with transmitter enter in auto hover mode.
  • provide full 6V to the servos for maximum performance
  • assisted in-flight controls
Missing:
  • a logging module could be useful (blackbox style)
  • RPM sensor (not sure what the best approach for this could be yet)
  • temp sensor (not really sure if this is useful or not)
  • bluetooth with a android companion app to visualize data (real-time data / something with more range that bluetooth?)
  • camera stabilizer
i'm aware of the ardupilot project but i dont want a UAV.
what do you guys think? comments? suggestions?
also i have to add i'm very new to electronics, i'm starting to learn am using this project as a learning opportunity.
If you're close enough to use bluetooth, you're going to be in danger of getting bits of rotor blade embedded in you.
You didn't say how big the copter is, but you might take a look at the JeeNode. It's
about as small as a 28 pin DIP Arduino board can be. Runs off 3.3V v.reg, and has
an RF transceiver so you can talk to it. Would need a 3.3V IMU.
http://jeelabs.com/products/jeenode
The heli is big a 600 class (1200mm)
The bt idea was to get the data out of the heli on the field, for realtime i would need some with more range, probably wifi.
one of the things i wanted to do with this projects was to do my first PCB, so this will be using a standalone arduino board, with the atmega328p.
Hi nice to know i have a colleague, i'm trying to build a quadrotor with just an Arduino UNO and an old 4ch RC set, i've got the first parts of the hard job almost done, i connected the RC with the UNO and managet to work them together then i wrote the skeleton for the software and a basic open loop trial version
i'm starting the prototyping with a small quadcopter but the control interface i have designed will surely suit on a hely
in my plans there are an octocopter with rotor redundancy and a gas powered hely with on board generator and a small 2S LiPofor backup power, just to fill the tank and fly for hours
see ya
