On door open - Logic problem
It never happened, It's sliding, without hinges.
I just have to find a way to make it work in as much as possible situations without adding an PIR sensor or any other extra sensors. The most often situation is when you left door open. Maybe if I make the LED switch when you close the door, and not when you open it could help a little.
