ON(LOW) in 1 second and then OFF(HIGH), using delay. anyone can help?
Hey guys, i just want to know about my code using delay instead of millis, my case 4 relay, one of them must be off after 1 second. my code here.
/*Multiple state handling
#define capSwitch D4 //tombol
#define relay1 D0
#define relay2 D1
#define relay3 D2
#define relay4 D3
int state = 0;
int old = 0;
int buttonPoll = 0;
pinMode(capSwitch,INPUT);
pinMode(relay1,OUTPUT);
pinMode(relay2,OUTPUT);
pinMode(relay3,OUTPUT);
pinMode(relay4,OUTPUT);
digitalWrite(relay1,HIGH);
digitalWrite(relay2,HIGH);
digitalWrite(relay3,HIGH);
digitalWrite(relay4,HIGH);
buttonPoll = digitalRead(capSwitch);
if(buttonPoll == 1){
delay(50);
if(buttonPoll == 0){
state = old + 1;
else{
delay(100);
switch (state) {
case 1: //on
digitalWrite(relay1,LOW);
old = state;
case 2: //acc
digitalWrite(relay2,LOW);
digitalWrite(relay3,LOW);
old = state;
case 3: //stater
if (digitalWrite(relay2) == LOW) {
digitalWrite(relay4,LOW); //this must HIGH after 1000ms
old = state;
default: //posisi mati/off
old = 0;
start-stop-ignition.ino (1.53 KB)
Do you have a question?
“ using delay instead of millis,” ???
We never use delay here :wink:
So sorry i'm new in arduino, can anyone help for my code, in my code case 3 relay1,2,3 and 4 should ON if press button 3 times, and i want to make relay 4 auto OFF after 1 second ON, and i don't know how to use millis and insert it to my code, using delay is looping that relay, and error compiling. i don't know how :frowning:
What do you think is happening here?
How is ‘capSwitch’ wired?
To be tested.
What do you not understand?
// Multiple state handling
//Version 1.00
#define relayOFF  HIGH
#define relayON   !relayOFF
#define PUSHED    HIGH
#define relay1    2
#define relay2    3
#define relay3    4
#define relay4    5
#define capSwitch 6 //tombol  HIGH = pushed?
//when relay4Flag is true we are timing relay 4
boolean relay4Flag = false;
byte state      = 0;
byte buttonPoll = 0;
byte lastButtonPoll;
//timing stuff
unsigned long switchMillis;
unsigned long relay4Millis;
const unsigned long relay4Interval = 1000;  //one second
  pinMode(capSwitch, INPUT);  //pushed = HIGH?
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay4, OUTPUT);
  digitalWrite(relay1, relayOFF);
  digitalWrite(relay2, relayOFF);
  digitalWrite(relay3, relayOFF);
  digitalWrite(relay4, relayOFF);
} //END of setup()
  //is it time to check our switches? (every 50 millis seconds)
  if (millis() - switchMillis >= 50)
    //restart this timer
    switchMillis = millis();
    //see what's happening with our switches
    checkSwitches();
  //when we are timing relay 4, has the timer finished?
  if (relay4Flag == true && millis() - relay4Millis >= relay4Interval)
    //disable timing
    relay4Flag = false;
  //check the StateMachine
  stateMachine();
  // other none blocking code goes here
} //END of loop()
void checkSwitches()
  //has the switch changed state?
  if (lastButtonPoll != buttonPoll)
    //update to the new state
    lastButtonPoll = buttonPoll;
    //is the switch PUSHED
    if (buttonPoll == PUSHED)
      //do nothing
    //switch has been released
      state++;
      if (state > 4)
        state = 0;
        //disable timing
        relay4Flag = false;
  } //END of if (lastButtonPoll != buttonPoll)
} //END of checkSwitches()
void stateMachine()
  switch (state)
    case 0:
      //do nothing
    case 1: //on
      digitalWrite(relay1, relayON);
    case 2: //acc
      digitalWrite(relay2, relayON);
      digitalWrite(relay3, relayON);
    case 3: //stater
      //enable timing
      relay4Flag = true;
      digitalWrite(relay4, relayON);
      //start timer
      relay4Millis = millis();
      state = 4;
    case 4:
      //do nothing
    default:
  } //END of switch/case
} //END of  stateMachine()
Thank you! Glad to be here! i just done re-wrote the code, and no way out, then i check the forum, finally that code work for me :smiley: big thanks to you @larryd. this is the code before i see the forum.
#define relay1 D1
#define relay2 D2
#define relay3 D3
#define relay4 D5
int buttonPoll = 0;
int carRunState = 0;
  boolean success;
  if (success) {
  if ((buttonPoll == 1) && (carRunState == 0)){
    carRunState = carRunState++;
  else if ((buttonPoll == 1) && (carRunState == 1)){
  else if ((buttonPoll == 1) && (carRunState == 2)){
  else if ((buttonPoll == 1) && (carRunState > 2)){
    carRunState = 0;
then i see this, so speechless…
larryd:
To be tested.
//Version 1.00
#define PUSHED    HIGH
#define relay1    2
#define relay2    3
#define relay3    4
#define relay4    5
byte state      = 0;
//timing stuff
} //END of setup()
//see what’s happening with our switches
    checkSwitches();
    //disable timing
    relay4Flag = false;
  stateMachine();
} //END of loop()
      //do nothing
      state++;
if (state > 4)
        state = 0;
        //disable timing
        relay4Flag = false;
void stateMachine()
  switch (state)
    case 0:
      //do nothing
    case 1: //on
    case 2: //acc
    case 3: //stater
//enable timing
      relay4Flag = true;
      //start timer
state = 4;
    case 4:
      //do nothing
    default:
sketch_jan01d.ino (1.45 KB)
#define relay1 D1 <-----<<<<
D0 and D1 are used for the Serial communications.
Use D2-D13 and A0-A5 on an Arduino UNO.
Remember, you can only learn if you get answers to things you don’t understand :wink:
My fault no check again, i just wonder, you make void checkswitches for capSwitch and have 4 state, if i make one virtual pin from the state 3 how is this possible?
There are 5 states 0, 1, 2, 3, and 4.
“ if i make one virtual pin from the state 3 how is this possible?”
I do not understand, please rephrase your question.
I want to connect to blynk, just use state 3 to write all the relay just 1 times push button virtually from virtual pin. Is that possible
I have not used blynk.
Maybe this:
//Multiple state handling
//Versioin 1.1
#define RELAYoff  HIGH
#define RELAYon   !RELAYoff
#define PUSHED    HIGH
#define relay1    2
#define relay2    3
#define relay3    4
#define relay4    5
//when relay4Flag is true, we are timing relay 4
byte state      = 0;
//timing stuff
  digitalWrite(relay1, RELAYoff);
  digitalWrite(relay2, RELAYoff);
  digitalWrite(relay3, RELAYoff);
  digitalWrite(relay4, RELAYoff);
} //END of setup()
    checkSwitches();
    //disable timing
    relay4Flag = false;
  stateMachine();
} //END of loop()
      //do nothing
      state++;
void stateMachine()
  switch (state)
    case 0:
      //do nothing
    case 1: //on
      digitalWrite(relay1, RELAYon);
    case 2: //acc
      digitalWrite(relay2, RELAYon);
      digitalWrite(relay3, RELAYon);
    case 3: //stater
      //enable timing
      relay4Flag = true;
      digitalWrite(relay4, RELAYon);
      //start timer
      state = 4;
    case 4:
      //do nothing
    default:
      state = 0;
      //disable timing
      relay4Flag = false;
