On/Off Button and Volume changing Potientometer
I have this task where I have to build a simple musical device that plays the Chorus of our school song, every time a button is pushed. A second button (or a potentiometer) will fade the volume up or down. I have no idea on what to do and the rest of the class is stuck on the same thing. I have got the song down pat, all I need is the coding and layout for the volume and the 'on' button. It doesn't need to turn it off. We can also use a button to change the volume. I would really appreciate it if someone could help because I am absolutely HOPELESS (If you want to see my coding, please just ask. There will be some errors in there and I will be delighted if you could pick them up)
how about an iPod? ;)
That's the "hard part." You'll need an "audio shield" or "MP3 shield". The shield will have the memory to store the song and the digital-to-analog converter. So, the Arduino is just a "controller".
...every time a button is pushed.
That's just an if-statement in software. Look at the [u]button example[/u].
A pot at the analog output is the easiest way to go. Make sure to get an "audio taper" pot. Your ears are not linear and a regular linear pot will sound too loud at the half-way point. But... You'll need an amplifier to drive a speaker and the amp should have a volume control already.
Or, if the audio shield you choose has digital volume control, you can use either a pot on an Arduino analog input, or volume-up and volume-down buttons on digital inputs (again with if-statements).
