on off times wont work?
hi iv been trying to get my relay on off to work on AM times and PM times
for my AM START_HOUR1=6 AM to STOP_HOUR1=8 AM this works no problem
if ((now.hour() >= START_HOUR1 && now.hour() <= STOP_HOUR1))
but i would like to do a PM also START_HOUR2= 6 PM to STOP_HOUR2= 8 PM
  if ((((now.hour() >= START_HOUR1 && now.hour() <= STOP_HOUR1 or now.hour() >= START_HOUR2 && now.hour() <= STOP_HOUR2))))
the if statement above will start my AM on off no problem but my PM starts ON but WONT turn off STOP_HOUR2= 8 PM
please help
What value / type are all the START_HOUR and STOP_HOUR variables?
24 hour times are better for this.
Even better, use "minutes past midnight" or "seconds past midnight" for timing intervals.
#define BAT_VOLT1  46.00      // RELAY1 LOW BAT VOLTAGE RELAY OFF
#define Max_Watts1  1500          //CT1/ solar / RELAY1// RELAY ON/OFF
#define START_HOUR1   6  // RELAY1 ON AM  0-23 hour 6=6AM
#define STOP_HOUR1    8  // RELAY1 OFF AM 0-23 hour 8=8AM
#define START_HOUR2   18  // RELAY1 ON PM  0-23 hour 18=6PM
#define STOP_HOUR2    20  // RELAY1 OFF PM 0-23 hour 20=8PM
float h2 = dht2.readHumidity();
// RELAYS
if (true)
// RELAY 1 AM/PM ON OFF PIN D12
  if ((Watts1 < Max_Watts1 && Voltage8 > BAT_VOLT1 && h2 < 70))
     //if ((((now.hour() >= START_HOUR1 && now.hour() <= STOP_HOUR1 or now.hour() >= START_HOUR2 && now.hour() <= STOP_HOUR2))))
      setStatusOfRelay(1, true);
      setStatusOfRelay(1, false);
Serial.printing the hour would be interesting. At least to validate that you're getting 24 hour times.
Fri 23:59:15 4-10-2020
Fri 23:59:23 4-10-2020
Fri 23:59:31 4-10-2020
Fri 23:59:39 4-10-2020
Fri 23:59:47 4-10-2020
Fri 23:59:55 4-10-2020
Sat 0:0:3 4-11-2020
Sat 0:0:12 4-11-2020
Sat 0:0:20 4-11-2020
Sat 0:0:28 4-11-2020
Sat 0:0:36 4-11-2020
Sat 0:0:44 4-11-2020
Time to post all your code, in code tags please.
should this if statement below work?
You forgot to post the code correctly with tags
I’d never write code like that , it’s very hard to read and prone to errors
Split up stuff over a few lines and add comments so when you look at it next year it still makes sense
. Not to sure about the “or” in there anyway , don’t think that exists as an instruction.
hammy:
Yes, it does... along with "and", "xor", "not", and bitwise equivalents like "bitand", "bitor", etc.
https://en.cppreference.com/w/cpp/keyword
i thought if you use a bad instruction like (or,and,&&,ect...) you would get a compile error and i dont
amir2:
It's great that you used "or", it's more readable. You should also change every "&&" to "and", or else change every "or" to "||" to be consistent.
ok i changed the (&& to and) change (or to ||) now it works but dont understand why or how
#define START_HOUR1   5  // RELAY1 ON AM  0-23 hour 6=6AM
#define STOP_HOUR1    6  // RELAY1 OFF AM 0-23 hour 8=8AM
#define START_HOUR2   7  // RELAY1 ON PM  0-23 hour 18=6PM
#define STOP_HOUR2    9  // RELAY1 OFF PM 0-23 hour 20=8PM
Relay 1  ON | Relay 2  OFF | Relay 3  OFF | Relay 4  OFF | Relay 5  OFF | Relay 6  OFF | Wed , 9:53:11 , 5/20/2020
Relay 1  OFF | Relay 2  OFF | Relay 3  OFF | Relay 4  OFF | Relay 5  OFF | Relay 6  OFF | Wed , 10:0:2
the AM start stop works right START_HOUR1 ,STOP_HOUR1 but the PM START_HOUR2 ,STOP_HOUR2 doesn't stop until a hour after but i can live with that il just change my STOP_HOUR2 to 1 hour earlier
if ((((now.hour() >= START_HOUR1 and now.hour() <= STOP_HOUR1 || now.hour() >= START_HOUR2 and now.hour() <= STOP_HOUR2))))
Didn’t know that !! I’ve only ever used the instruction set as per the Arduino reference page which gives the confusing AND , OR squiggles.
amir2:
You did not understand me. You should use "and, or" or else "&&, ||" but not mix them together in the same line.
