On SD card I can not list files after writing to SD card
I have searched various sites and cannot find a reason or fix for this issue.
The project is a controller / data logger with a web interface to show the data.
I have found that once I have written to a file I can no longer list what files are on the SD card.
The Shield is the Adafruit Ethernet shield R3.
The following is a simple example of the code that displays the issue
#include <SPI.h>
#include <SD.h>
File myFile;
   pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    return;
  myFile = SD.open("/");
  printDirectory(myFile, 0);
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    myFile.println("testing 1, 2, 3.");
    myFile.close();
void printDirectory(File dir, int numTabs) {
   while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');
     Serial.print(entry.name());
     Serial.print("\t\t");
     Serial.println(entry.size(), DEC);
     entry.close();
I suspect that I am missing a step to move a pointer back to the start of the directory although running the list does not exhibit the issue.
I have also tested with the Adafruit Datalogger shield and get the same results.
Please help.
Thank you and have a good day
I would try closing that open file after calling printDirectory().
  if (!SD.begin(4)) {
    return;
  if(myFile) {
    myFile.close();
  if (myFile) {
    myFile.close();
  if(myFile) {
    myFile.close();
Just a thought...
You should close files as suggested by SurferTim to avoid memory leaks.
You must position the root directory by calling seek() before calling printDirectory(). SD.h returns a pointer to an internal file object for root and does not reposition root to the beginning.
The best mod is to add the seek call to printDirectory();
#include <SPI.h>
#include <SD.h>
File myFile;
  if (!SD.begin()) {
    return;
  myFile.close();  //// Add close  /////////////
  if (myFile) {
    myFile.close();
  myFile.close();  ////// Add close  /////
   dir.seek(0); /////// Add seek ///////////////////
   while(true) {
     if (! entry) {
       Serial.print('\t');
     entry.close();
Hi all,
Thank you fat16lib the seek(0) did fix the issue.
Have a good day
How can I add a sequence number, the date and time to the file listing the sketch produces?
I experimented with many variations of the commands, without success. The problem lines are marked as //??
#include <SPI.h>
#include <SD.h>
File myFile;
  if (!SD.begin()) {
    return;
  if (myFile) {
    myFile.close();
  //See: http://forum.arduino.cc/index.php?PHPSESSID=0ft62ocf1i787r0vnaou4teaa6&topic=190889.0
   while(true) {
     if (! entry) {
       Serial.print('\t');
//??     Serial.print(i);Serial.print("\t");
//     Serial.print("\t\t");
//??     Serial.println(entry.Date(), DEC);
//??     Serial.println(entry.Time(), DEC);
     Serial.print("\t");
     entry.close();
i is the index in the for loop that is inserting tabs. Why would you want to print the number of tabs?
What IS the problem with:
Aside from the fact that the File class does not have Date() and Time() methods. Since the Arduino does not know what time it is, how can you expect it to date and time stamp files on the SD card?
1) I have used the //?? markings to identify the statements that do not work (when you take out the marking of course). You are right about printing multiple tabs. Thanks!
2) It is easy to time tag files using an Arduino sketch and some hardware. See: https://github.com/adafruit/RTClib
Any suggestions to get the date-time and the file size listed anyway (See my earlier post) as part of the sketch listed?
