Hi, I shared my dashboard to a user, and also upgraded both account to maker plan. but the problem is that the push notification is only popping at the owner account (my account) . is there a way that the other user to received the same notification? thanks
Hi @randelldavid44,
thank you to reaching out to us.
If you share a dashboard to a user this doesn't allow to send a Push Notifications to that user.
This is a feature of Triggers and you can add a user from the Trigger page you have associated with the variable. See the documentation for more infos https://docs.arduino.cc/arduino-cloud/iot-remote-app/push-notifications/
In your case if you want to add a user to the Trigger you need an enterprise (pro) space. The private space doesn't allow to add more then one user to a Trigger (the owner).
Thanks
