onboard LED and motion detector
I need some code for a motion detector to turn on the onboard LED.
Here you go:
   if (getMotionState() == DETECTED) {
      turnLEDOn();
      turnLEDOff();
I'm new to arduino the does not work.
I'm testing a HC-SR501 motion detector.
If I upload to a nodemcu v3 it randomly kernel panics my macbook air. If does not turn on the onboard LED or print to the serial monitor.
It work on my Uno.
int pirPin = 2;    //the digital pin connected to the PIR sensor's output
int ledPin = 13;
int val;
//SETUP
void setup(){
  pinMode(pirPin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);
//LOOP
void loop(){
  val = digitalRead(pirPin);
  if(val == HIGH)
    Serial.println(" HIGH");
    digitalWrite(LED_BUILTIN, HIGH);
    digitalWrite(LED_BUILTIN, LOW);
    Serial.println(" LOW");
  delay(2000);
Have a look at How to use the forum. We are NOT a code writing service!
If you want the code written for you, go here. But don't be surprised people want to get some money for it.
