Once again a newbe asking for your help  Ping sens
Hi, I been lerarning the arduino, I am newbe in programing and arduino. I have a parallax Ping sesor working, using the example code from arduino IDE, my question is... How can make it to printline when and object is at lets say 24 inches away from sensor. thank you in advance
newbe ansious to learn and help :)
Assuming you have been playing around with the playground code found here: http://www.arduino.cc/playground/Main/UltrasonicSensor
I would probably do something like this.
 int x = 0;
 x = ping();
 if(( x < 25)||(x > 24)) {
  Serial.println(x);
 delay(250); //delay 1/4 seconds.
As there are many ways to do this, this is just a quick example of one of them. The line I added is the “if” statement, and what I’m doing is saying if x is less than 25 OR x greater than 24, print the line out from the serial.
To understand more on how to read and work with conditional data check out http://arduino.cc/en/Reference/HomePage control structures, and specifically the if, and if…else options.
Hope this helps,
-Chris G.
thank you somuch
this code http://www.arduino.cc/playground/Main/UltrasonicSensor
is actually the best so far, measure more acure and clean
now this code
 int x = 0;
 x = ping();
  Serial.println(x);
would you explain the line
thank you in advance.
I really thank you for your help.
;D
The double bar symbol is the C "logical OR" operator. "If x is less than 25 OR x is greater than 24".
Hmm... now that doesn't make sense. It'll always be TRUE, I think. Maybe it should be:
if (x == 24) {
...assuming that the original plan was to print the message only when the detected target was 24 inches from the sensor, and the "ping" function returns distance directly in inches.
is making sence
thanks guys
here is code that I am using now
// * Copyleft 2007 Jason Ch
//This code returns the distance in Inches... I think it's more accurate than other code I have seen online and returns more usable results. Remove the *.39 to return cm instead of inches. You could make float ultrasoundValue = 0; but then you can't print it unless you transfer it into another type, but it could be used for further calculations.
 unsigned long echo = 0;
 int ultraSoundSignal = 7; // Ultrasound signal pin
 unsigned long ultrasoundValue = 0;
 pinMode(ultraSoundSignal,OUTPUT);
 unsigned long ping(){
 pinMode(ultraSoundSignal, OUTPUT); // Switch signalpin to output
 digitalWrite(ultraSoundSignal, LOW); // Send low pulse
 delayMicroseconds(2); // Wait for 2 microseconds
 digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
 delayMicroseconds(5); // Wait for 5 microseconds
 digitalWrite(ultraSoundSignal, LOW); // Holdoff
 pinMode(ultraSoundSignal, INPUT); // Switch signalpin to input
 digitalWrite(ultraSoundSignal, HIGH); // Turn on pullup resistor
  echo = pulseIn(ultraSoundSignal, HIGH); //Listen for echo
  ultrasoundValue = (echo / 58.138) * .39; //convert to CM then to inches
 return ultrasoundValue;
 int x = 0;
 x = ping();
 if( x < 25) {
  Serial.println("AAAAAAAAAAAAAAA");
 delay(2250); //delay 1/4 seconds.
what is 25 for, inches, cm. or just raw data.
Is that a typo? One quarter of a second would be 'delay (250);'.
Correct me if I'm wrong, but since we are dealing with floats, the logic would be if the value is less than 25.0 but more than 24.0 (aka 24.1, 24.3, 24.989283940890) do the function. I guess the better math would have been to use if x >= 24 so that you will do the function at 24.0.
-Chris G.
Correct me if I’m wrong, but since we are dealing with floats,
We’re dealing with ints:
int x = 0;
That would require the AND operator:
if ((x < 25) && (x > 24)) {
Which won’t work with ints, but would work with floating-point:
double x;
if ((x < 25.0) && (x > 24.0)) {
Wow, yup, I see I was wrong on almost every part. Teach me to try to reply to posts late at night after a long day at work.
Thanks for correcting me Anachrocomputer
-Chris G.
