One example:
Here I calculate the absolut voltage difference (CloudElectricPotential voltageDifference) between the two batteries:
//Berechne die absolute Differenz der beiden Batteriespannungen
voltageDifference = fabs(battery01Voltage - battery02Voltage);
Whenever this is calculated I exptected that function onVoltageDifferenceChange(); would be called as there, I do a couple of things like:
- Deciding if I need to change the state of bool batteryDiffernenceAlert, basically deciding if I have to trigger an alert.
- Deciding if I have an anusual condition like voltage being to high or to low and deciding if I have to active Mosfet's who will balance the batteries, if triggered.
This works all fine, but not because onVoltageDifferenceChange() is called because 'CloudElectricPotential voltageDifference' has changed, it only works, because I call onVoltageDifferenceChange() regularly from loop().
Does this make sense to you?
