One "2 PIN Button" on 2 GPIO Pins
Hey Arduino Friends,
i have a question about the digital Pins. Because i am using Arduino Due with enough digital Pins, i want to connect some Buttons (until WIFI and App is finished to takes control) and i dont want to use my breadboard.
So i used an 2x pin stripe to connect the Button / Wires. Now i want to check the Button State programmatically. It works but i am not sure if it is a good solution (electronics).
Without a diagram or code we can't tell you... And what's "2x pin strip" or a 2 PIN Button"?
I believe it's a push button you are connecting. Normally I check the button state using digitalRead and I dont find any issue with that.
Sorry, the image can not be uploaded. Trying again.
I am using some normal Push Button with two wires and soldered with 2 Pins to connect it directly to the Ar. Due.
My Code looks like this:
Setup:
  pinMode(PIN_BUTTON_2_OUT, OUTPUT);
  digitalWrite(PIN_BUTTON_2_OUT, LOW);
  pinMode(PIN_BUTTON_2_IN, INPUT);
  digitalWrite(PIN_BUTTON_2_IN, HIGH);
Loop:
  if(digitalRead(PIN_BUTTON_2_IN)==LOW){ Serial.print("Button 2 is pressed!\r\n"); }
If it's just a normal push button than this is a bit wasteful. Just connect one side to GND and the other to a pin. Then you don't need the:
A normal button doesn't need a output.
Then you're left with on input on which you turn on the internal pull up. You can do that with
But you can also do it in one line, which I find more clear
pinMode(PIN_BUTTON_2_IN, INPUT_PULLUP);
Little code tip, a line is done after a { or a ;. So:
if(digitalRead(PIN_BUTTON_2_IN) == LOW){
  Serial.println("Button 2 is pressed!");
Makes the code clearer.
And by using println() you can skip the whole line end stuff :wink:
A photo of the connection is very difficult to understand, a schema drawn in Fritzing or any other tool is easily readable.
I normally use the code approach you mentioned in the post.
To connect switches I used the Internal pull-up resistor approach mentioned in post Gammon Forum : Electronics : Microprocessors : Switches tutorial
Thank u both for explanation and the Link.
...is better to understand.
I used GND and the internal pullup before. Works well. the Problem is, that i need to use some more Buttons and Sliders and the Wires between Breadboard, Arduino, Buttons, ... are driving me crazy. :o)
So while development i would like to connect the Buttons directly to 2 GPIO Pins. But im still not sure if the Code is 'electrically' ok?!
Yes it is. But adding all the LOW outputs just to create GND's for switches doesn't help the code being readable.
If you need multiple buttons in a test situation and a breadboard is driving you crazy (tip, small solid core wire like this already keeps it more manageable) then just get out your soldering iron and make a small PCB :wink:
Small PCB :), that's what i do normally after a prototyping in breadboard. Wires drives me crazy :), takes me an hr or two to etch a simple home made pcb and drill holes.
But you don't need to make it that fancy... Just a prototype PCB, takes you 5 minutes. Just solder on more buttons then you ever need and you can re-use it every time you need buttons.
Thank u both. :slight_smile:
Since it is my first project and I have no experience with electrical engineering, I am pleased with all instructions. However, since almost all components will be shipped from China, I will buy next week a prototype pcb in the electronics shop in the city.
Maybe i will try an playstation controller because it seems to be connected with something like spi communication.
