"One-Arm-Bandit" with arduino
Hello
I wanna make a "One-Arm-Bandit" Machine with arduino code. For this, i need 3 Numbers that are in the Range of 0-9. Its the machine, that has a lever on the side, and 3 wheels with icons. If you start it, the wheels will turn and stop at a time. If 2 or more Symbols are the same, you win something.
If a button is pressed, the numbers start cycling from 0 up do 9 in a fixed interval. If the button is released, the numbers should cycle for a RANDOM time (lets say in range from 2 to 8 seconds) and then come to a random number stop. The first number should stop first, then the other two.
The actual number should be accessable all the time.
Has anyone made something like this? Or could give me a example how to do something like this?
// slot machine
// led matrix:
// 0_0, 0_1, 0_2
// 1_0, 1_1, 1_2
// 2_0, 2_1, 2_2
#define SLOT_MACHINE_ROWS    3
#define SLOT_MACHINE_COLUMNS 3
#define SLOT_MACHINE_STATUS_INIT_RUN 0
#define SLOT_MACHINE_STATUS_RUNNING  1
#define SLOT_MACHINE_STATUS_STOPPED  2
int globalStatus;
unsigned long startRunningTime;
const long maxRunningPhaseDuration = 7000L;
const int ledPin[SLOT_MACHINE_ROWS][SLOT_MACHINE_COLUMNS] = {{2, 3,  4},
                                                             {5, 6,  7},
                                                             {8, 9, 10}};
int ledState[SLOT_MACHINE_ROWS][SLOT_MACHINE_COLUMNS] = {{LOW, LOW, LOW},
                                                         {LOW, LOW, LOW},
                                                         {LOW, LOW, LOW}};
long ledStateLastWentHigh[SLOT_MACHINE_ROWS][SLOT_MACHINE_COLUMNS] = {{0L, 0L, 0L},
        {0L, 0L, 0L},
        {0L, 0L, 0L}};
long singleLedHighTimePerColumn[SLOT_MACHINE_COLUMNS] = {600L, 300L, 600L};
const long maxSingleLedHighTimePerColumn[SLOT_MACHINE_COLUMNS] = {1000L, 1000L, 1000L};
const long singleLedHighTimeIncrement = 100L;
    for (int i = 0; i < SLOT_MACHINE_ROWS; ++i)
        for (int j = 0; j < SLOT_MACHINE_COLUMNS; ++j)
            pinMode(ledState[i][j], OUTPUT);
    globalStatus = SLOT_MACHINE_STATUS_INIT_RUN;
    switch (globalStatus)
        case SLOT_MACHINE_STATUS_INIT_RUN:
            initRunPhase();
        case SLOT_MACHINE_STATUS_RUNNING:
            runningPhase();
        default: // SLOT_MACHINE_STATUS_STOPPED
            stoppedPhase();
// runtime phases
void initRunPhase()
    // turn on first row
        ledState[0][j] = HIGH;
    digitalWriteAllLeds();
    startRunningTime = millis();
        ledStateLastWentHigh[0][j] = startRunningTime;
    globalStatus = SLOT_MACHINE_STATUS_RUNNING;
void runningPhase()
    bool needDigitalWriteAllLeds = false;
    unsigned long runningTime = millis() - startRunningTime;
    if (runningTime < maxRunningPhaseDuration)
            int highLedIndex = firstHighLedIndexInColumn(j);
            long ledStateTimeSinceLastWentHigh = millis() - ledStateLastWentHigh[highLedIndex][j];
            if (ledStateTimeSinceLastWentHigh > singleLedHighTimePerColumn[j])
                int nextHighLedIndex = (highLedIndex + 1) % SLOT_MACHINE_COLUMNS;
                ledState[highLedIndex][j] = LOW;
                ledState[nextHighLedIndex][j] = HIGH;
                ledStateLastWentHigh[nextHighLedIndex][j] = millis();
                needDigitalWriteAllLeds = true;
        // update output pins if needed
        if (needDigitalWriteAllLeds)
        globalStatus = SLOT_MACHINE_STATUS_STOPPED;
void stoppedPhase()
    // do nothing
void digitalWriteAllLeds()
            digitalWrite(ledPin[i][j], ledState[i][j]);
int firstHighLedIndexInColumn(int columnIndex)
    int rowIndex = -1;
    int i = 0;
    while (rowIndex == -1 && i < SLOT_MACHINE_ROWS)
        if (ledState[i][columnIndex] == HIGH)
            rowIndex = i;
            ++i;
    return rowIndex;
// shift register functions
int numberToDisplay(short bit7, short bit6, short bit5, short bit4,
                    short bit3, short bit2, short bit1, short bit0)
    int res = 0;
    short input[] = {bit0, bit1, bit2, bit3, bit4, bit5, bit6, bit7};
    for (int i = 0; i < 8; ++i)
        if (input[i])
            res += ipow(2, i);
    return res;
int ipow(int base, int exp)
    int res = 1;
    while (exp)
        if (exp & 1)
            res *= base;
        exp >>= 1;
        base *= base;
    return res;
