I'm using one button arduino library
I'm using encoder as a input.
used following program fo
This is a sample sketch to show how to use the OneButtonLibrary
to detect click events on 2 buttons in parallel.
The library internals are explained at
Arduino OneButton Library
Setup a test circuit:
- Connect a pushbutton to pin A1 (ButtonPin) and ground.
- Connect a pushbutton to pin A2 (ButtonPin) and ground.
- The Serial interface is used for output the detected button events.
The Sketch shows how to setup the library and bind 2 buttons to their functions.
In the loop function the button1.tick and button2.tick functions have to be called as often as you like.
// 01.03.2014 created by Matthias Hertel
// ... and working.
/* Sample output:
Starting TwoButtons...
Button 1 click.
Button 2 click.
Button 1 doubleclick.
Button 2 doubleclick.
Button 1 longPress start
Button 1 longPress...
Button 1 longPress stop
Button 2 longPress start
Button 2 longPress...
Button 2 longPress stop
#include "OneButton.h"
// Setup a new OneButton on pin A1.
OneButton button1(A1, true);
// setup code here, to run once:
// Setup the Serial port. see if(Serial) - Arduino Reference
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// link the button 1 functions.
button1.attachClick(click1);
button1.attachDoubleClick(doubleclick1);
button1.attachLongPressStart(longPressStart1);
button1.attachLongPressStop(longPressStop1);
button1.attachDuringLongPress(longPress1);
} // setup
// main code here, to run repeatedly:
// keep watching the push buttons:
button1.tick();
// You can implement other code in here or just wait a while
delay(10);
} // loop
// ----- button 1 callback functions
// This function will be called when the button1 was pressed 1 time (and no 2. button press followed).
void click1() {
Serial.println("Button 1 click.");
} // click1
// This function will be called when the button1 was pressed 2 times in a short timeframe.
void doubleclick1() {
Serial.println("Button 1 doubleclick.");
} // doubleclick1
// This function will be called once, when the button1 is pressed for a long time.
void longPressStart1() {
Serial.println("Button 1 longPress start");
} // longPressStart1
// This function will be called often, while the button1 is pressed for a long time.
void longPress1() {
Serial.println("Button 1 longPress...");
} // longPress1
// This function will be called once, when the button1 is released after beeing pressed for a long time.
void longPressStop1() {
Serial.println("Button 1 longPress stop");
} // longPressStop1
// End
