one button start on timer with increase time for 2nd or more press
Hi All,
im new here, currently i'm working a timer project with only 1 button to start timer & increase time if current time not end .
exp :on timer time set 20sec, if within 20sec i press again the button it will add another 20sec on current time.
but i try many way it cant work :cry:
below my code please help & advise me Thanks:
#define led 13
boolean Rled = false;
long current = 0;
long RoffTime = 0;
boolean Rledon = false;
boolean Rledoff = false;
const int buttonPin = 2;
int buttonState = 0;
pinMode(buttonPin, INPUT);
pinMode(13, OUTPUT);
if (digitalRead(buttonPin) == HIGH) {
current = millis()+ 20000;
Rled = false;
Rledon = false;
Rledoff = true;
digitalWrite(led, HIGH);
if((millis() > (current + RoffTime)) && Rledoff == true && Rledon == false){
Rledon = true;
else {
if(Rledon == true){
digitalWrite(led, LOW);
Rledoff = true;
couldn't follow logic of your code
i believe the following does what you intended, demonstrates detection of a button press (not simply held) and how to time events without blocking
#if 0
# define led 13
#else
# define led 10
const int buttonPin = A1;
#endif
#define ON      LOW
#define OFF     HIGH
#define PRESSED LOW
void setup () {
   pinMode (buttonPin, INPUT_PULLUP);
   pinMode (led, OUTPUT);
   digitalWrite (led, OFF);
// turn led on when button pressed
// extend time if button pressed while LED on
void loop () {
   // turn off LED when time expired
   static unsigned long msecLst = 0;
          unsigned long msec    = millis ();
#define ON_TIME  3000
   if (msecLst && msec - msecLst > ON_TIME)  {
       msecLst = 0;
   // detect button press
   static byte butLst = ! PRESSED;
          byte but    = digitalRead (buttonPin);
   if (butLst != but)  {
       butLst = but;
       if (PRESSED == but)  {
           msecLst = msec;
           digitalWrite (led, ON);
Hi gcjr,
Thanks for help, sorry for my bad to confuse you,
actually i need a timer :
1- preset 20sec once press led will on for 20sec
2- if within 20sec i press again it will extend another 20sec on the current time (example: current time balance 10sec it add 20sec = 30sec) same go if i press the button 3 times = 20sec x 3 + current balance time.
Thanks
when a button is pressed and msecLst is not set, it needs to be set to msec. If msecLst is set, add 20000 to it.
Hi Gcjr,
Sorry my bad, i have trying many way follow your advise but still unable, could you please advise.
Thanks
const byte ButtonPin = 2;
unsigned long StartTime = 0;
unsigned long Interval = 0;
  pinMode(ButtonPin, INPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  if (digitalRead(ButtonPin) == HIGH)
    if (StartTime != 0)
       // Timer already running
      Interval += 20000UL;   // Increase the timer interval by 20 seconds
      StartTime = currentMillis;
      Interval = 20000UL;  // Start with a 20-second interval
      digitalWrite(LED_BUILTIN, HIGH);  // LED on
  // If the timer is running, test to see if the timer has expired
  if (StartTime != 0 && currentMillis - StartTime >= Interval)
    // Timer has finished
    digitalWrite(LED_BUILTIN, LOW);  // LED off
    StartTime = 0; // Timer not running
Hi Johnwasser.
Thanks, It work.
Really Appreciate your help
