Hello, I just want to make one button that triggers an action on my Mac OSX 13.5.2 M2.
I have connected one push button to PIN 2 and GND. As stated on the Arduino Sample Sketch.
When I push the button, it should trigger the keyboard shift+command+m
I used this code for that:
Keyboard logout
This sketch demonstrates the Keyboard library.
When you connect pin 2 to ground, it performs a logout.
It uses keyboard combinations to do this, as follows:
On Windows, CTRL-ALT-DEL followed by ALT-l
On Ubuntu, CTRL-ALT-DEL, and ENTER
On OSX, CMD-SHIFT-q
To wake: Spacebar.
Circuit:
- Arduino Leonardo or Micro
- wire to connect D2 to ground
created 6 Mar 2012
modified 27 Mar 2012
by Tom Igoe
This example is in the public domain.
https://www.arduino.cc/en/Tutorial/KeyboardLogout
#define OSX 0
#define WINDOWS 1
#define UBUNTU 2
#include "Keyboard.h"
// change this to match your platform:
int platform = OSX;
// make pin 2 an input and turn on the pull-up resistor so it goes high unless
// connected to ground:
pinMode(2, INPUT_PULLUP);
Keyboard.begin();
while (digitalRead(2) == HIGH) {
// do nothing until pin 2 goes low
switch (platform) {
case OSX:
Keyboard.press(KEY_LEFT_GUI);
// Shift-Q logs out:
Keyboard.press(KEY_LEFT_SHIFT);
Keyboard.press('W');
delay(100);
Keyboard.releaseAll();
// enter:
Keyboard.write(KEY_RETURN);
case WINDOWS:
// CTRL-ALT-DEL:
Keyboard.press(KEY_LEFT_CTRL);
Keyboard.press(KEY_LEFT_ALT);
Keyboard.press(KEY_DELETE);
delay(100);
// ALT-l:
delay(2000);
Keyboard.press('l');
case UBUNTU:
// CTRL-ALT-DEL:
// Enter to confirm logout:
// do nothing:
while (true);
The strange thing is when I connect to my Mac and push the trigger. It does this shift+command+m once and then not going back when I push it again. The purpose is it should trigger mic off and on with one button.
How can I achieve this? Adapting the code using another code?
