Hey Friends,
I try to use one of the PS3 Buttons to switch a relay on ore off. First Press On, Second Press off. It Wont work and I don't know why.
Can u Help me?
* This example shows how to control MDDS30 in PWM mode with Arduino.
* Set MDDS30 input mode to 0b10110100
* Open Serial Monitor, set baudrate to 9600bps and "No line ending".
* Hardware Connection:
* Arduino Uno MDDS30
* GND ---------- GND
* 4 ------------ IN1
* 5 ------------ AN1
* 6 ------------ AN2
* 7 ------------ IN2
* Related Products:
* - SmartDriveDuo-30: http://www.cytron.com.my/P-MDDS60
* - CT UNO: http://www.cytron.com.my/p-ct-uno
* - DC Brush Motors: http://www.cytron.com.my/c-84-dc-motor
* - LiPo Battery: http://www.cytron.com.my/c-87-power/c-97-lipo-rechargeable-battery-and-charger
* - Male to Male Jumper: https://www.cytron.com.my/p-wr-jw-mm65
* URL: http://www.cytron.com.my
#include <PS3BT.h>
#include <usbhub.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
#include <Cytron_SmartDriveDuo.h>
#define IN1 4 // Arduino pin 4 is connected to MDDS30 pin IN1.
#define AN1 5 // Arduino pin 5 is connected to MDDS30 pin AN1.
#define AN2 6 // Arduino pin 6 is connected to MDDS30 pin AN2.
#define IN2 7 // Arduino pin 7 is connected to MDDS30 pin IN2.
Cytron_SmartDriveDuo smartDriveDuo30(PWM_INDEPENDENT, IN1, IN2, AN1, AN2);
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
//PS3BT PS3(&Btd); // This will just create the instance
PS3BT PS3(&Btd, 0x00, 0x1A, 0x7D, 0xDA, 0x71, 0x13); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
char inChar;
signed int speedLeft, speedRight;
int mappedfahren;
int mappedlenken;
int schildY;
int mappedschildY;
int links = 0;
int rechts = 0;
const int light= 27;
const int extswitch = 28;
boolean oldstatlight = LOW;
boolean newstatlight = LOW;
boolean lightstat = LOW;
int counterlight;
pinMode(13, OUTPUT);
pinMode(light, OUTPUT);
pinMode(extswitch, OUTPUT);
digitalWrite(light,LOW);
digitalWrite(extswitch,LOW);
/*digitalWrite(13, HIGH);
speedLeft = 10;
speedRight = 10;
delay(1000); // Delay for 5 seconds.
digitalWrite(13, LOW);
//PS3 Controller Teil
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); //halt
Serial.print(F("\r\nPS3 Bluetooth Library Started"));
Usb.Task();
//Lampensteuerung
newstatlight=digitalRead(PS3.getButtonPress(CROSS));
if(newstatlight != oldstatlight)
{if (newstatlight == HIGH)
{if (lightstat == LOW)
{ digitalWrite(light,HIGH); lightstat == HIGH;}
else { digitalWrite(light,LOW); lightstat == LOW;}
oldstatlight = newstatlight;
//Lampensteuerung ENDE
if (PS3.PS3Connected || PS3.PS3NavigationConnected)
int fahren = PS3.getAnalogHat(LeftHatY);
mappedfahren = map(fahren, 0, 255, 100, -100);
int lenken = PS3.getAnalogHat(LeftHatX);
mappedlenken = map(lenken, 0, 255, 100, -100);
int schildY = PS3.getAnalogButton(R2);
mappedschildY = map(schildY, 0, 255, 0, 100);
/* Wertebreich verkleinern
mappedfahren = mappedfahren / 2;
mappedlenken = mappedlenken /2;
links = mappedfahren + mappedlenken;
rechts = mappedfahren - mappedlenken;
links = constrain(links, -100, 100);
rechts = constrain(rechts, -100, 100);
speedLeft = links;
speedRight = rechts;
Stop ();
if(PS3.getButtonClick(PS)) {
PS3.disconnect();
Stop();
smartDriveDuo30.control(speedLeft, speedRight);
void Stop()
speedLeft = 0;
speedRight = 0;
void Lampen()
