One more knight rider project - My first
Hallo and from me
recently i discovered the arduino world
i have ordered an arduino mega
i want to make two led bars like those on the mustung
i will use 2x46 leds
46 pins for the anodes
and 2 pins for all the kathodes on each bar (with transistors)
so i wiil be able to controll 92 leds
exept the nornal scan and the knight rider two thousand scan i want to use it as a vu meter
i will conect a mic on one analog input and read the value
the i map the analog read (0-1023) to the numbers of leds (0-91)
so if the number on leds (k) is below the middle i will turn on the first led bar and the number of the led that i want
if it is more than the half leds i will have to light all the half turn them off and light the other
but my questions is how can i write
do “something” for this ammount of time?
thanks
void k_leds_from_left_to_right (int k, int speedtime) // k(0,91)
if (k<= 45)
digitalWrite (leda,HIGH);
for (i=0; i=k; i++) // ligh the leds
digitalWrite (led*,HIGH);*
  • delay (speedtime); // wait with the leds on*
  • all_low();*
  • if (k>45)*
  • for (i=0; i=speedtime; i++)*
  • digitalWrite (leda,HIGH);*
  • for (j=0; j=45; j++)*
  • digitalWrite (led[j],HIGH);*
  • all_low();*
  • digitalWrite (ledb,HIGH);*
  • for (j=46; j=(46+k); j++)*
  • all_low();*
} // k_leds_from_left_to_right close
[/quote]
*all_low(); : makes all the ouputs low
i found the way
  if (k<= 45)
      digitalWrite (led[i],HIGH);
    all_low();
  timecounter = millis();
  timerunning = 0;
  if (k>45)
    for (i=1; ((timerunning-timecounter)<speedtime); i++ )
      all_low();
      all_low();
      timerunning = millis();
i got my arduino mega yesterday
and i have faced up some problems
first of all
my void loop section
  //********** Info display **********
  clearLCD(); // clear the lcd screen
  moveCursor("01", "01");
  displayMessage("    Made By:    ");
  moveCursor("02", "01");
  displayMessage("    herctrap    ");
  delay (1500);
  //get time from the sensor
  time = map(analogRead(speedo), 0, 1023, 20, 1000);
  // somewhere here i wiil read my digital and analog inputs and i will call some functgions
} // void loop close
but if i change it a litle bit to that
  delay (1500);
  displayMessage("    test    ");
then it loops and displays only the first message on the screen
i can see it to flick on the screen every 1.5 sec
i cant tell you if it reads the time from the sensor
also if i write
kitt2008scan (time); bellow to the //get time from the sensor time = map(analogRead(speedo), 0, 1023, 20, 1000);
still nothing happens it loops through the first meessage
also i have this below the void loop close
void kitt2008scan (int speedtime)
      int i;
      int j;
      digitalWrite (leda,HIGH); // both led bars work the same
      loop();
      for (i=0; i=45; i++) // going from the side to the middle by turning on the leds
       delay (speedtime);
      for (i=0; i=45; i++) // going from the side to the middle by turning off the leds
       digitalWrite (led[i],LOW);
       delay (speedtime);
       for (i=45; i=0; i--) // going from the middle to the side by turning on the leds
       delay (speedtime);
      for (i=0; i=45; i++)// going from the middle to the side by turning off the leds
       digitalWrite (led[j],LOW);
} // void kitt2008scan close
i removed the analogRead and it move on
  delay (1500);
  displayMessage("    MdsfBy:    ");
  displayMessage("    hcxcfzcra");
  delay (1500);
  time = 0;
// ------------------------------------------------------------------------------------------------------------------ scan patterns ------------------------------------------------------------------------------------------------------------------
Remind:
void knight_rider_two_thousand (int speedtime)
void four_groups_blink_twice (int speedtime)
void bar_blink_twice (int speedtime)
void bars_blink_twice (int speedtime)
void all_high()
void all_low()
void k_leds_from_middle_to_sides (int k, int speedtime) // k(45,0)
void k_leds_from_sides_to_middle (int k, int speedtime) // k(0,45)
  displayMessage(" 323 ");
  displayMessage(" 2121");
  delay (1500);
      int i;
      int j;
      loop();
     c
but now it loops through the 3 messages
shouldn't it to show each message one time
and then loops through
the
  delay (1500);
  delay (1500);
  time = 0;
Remind:
void all_high()
void all_low()
  delay (1500);
      int i;
      int j;
      loop();
       delay (speedtime);
       delay (speedtime);
       delay (speedtime);
  displayMessage("kitt2008scan");
  delay (1000);
      int i;
      int j;
  displayMessage("i j ");
  delay (1000);
  displayMessage("led a b");
  delay (1000);
      loop();
  displayMessage("looping");
  delay (1000);
       delay (speedtime);
       delay (speedtime);
       delay (speedtime);
it prints out only the kitt2008scan and i j not the looping
it goes from the begging
why ? it goes from the begging
why ?
Because of this:
      loop();
You call loop from the middle of your function. Of course, loop is going to start over.
so loop(); means
yes
i thought that it would start loopinh what it is inside the {} bellow of loop
i get it now
is there any other function / command for infinity loop
There are a couple of ways to create an infinite loop.
while(1)
   // Loop forever
for(;;)
   // Loop forever
Whichever you use, you need to provide a way to break out of the loop, if you want to do something else.
thanks more problems now
//******************** Led outputs ********************
int led[ ] = {53, 52, 51, 50, 49, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 32, 31, 30, 29, 28, 27, 26, 25, 24, 23, 22,   21, 20, 19, 18, 17, 16,   2, 3, 4, 5, 6, 7, 8, 9   };
//******************** Bar outputs ********************
int leda = 12;
int ledb = 13;
//************************************************************ inputs ************************************************************
 //********** i/o scan modes on analog inputs **********
 int scan1 = (8+54) ;
 int scan2 = (9+54);
 int scan3 = (10+54);
 int scan4 = (11+54);
 int scan5 = (12+54);
 int scan6 = (13+54);
 int scan7 = (14+54);
 //******************** inputs as i/o for the scan mode ********************
int simplescan = (0+54) ; // i/o switch for simple scann
int sensorenable = (1+54) ; // i/o switch for voice scan
int lightenable= (2+54) ; // i/o switch for light scan
int motionenable = (3+54) ; // i/o switch for motion enable scan
 //******************** analog inputs for the scan modes ********************
int speedo = 4; // analog input for speed controll
int sensor1 = 5;       // analog voice input for scan
int light = 6;      // analog input for light scan
int motion = 7;       // analog input for the motion detection
 //****************************** basic values ******************************
long calibrationtime = 5000; // the time limit for the calibration
int time; // for the time delay
//******************** for help ********************
int k;
long rnda; // for random production
long rndb;
int minvalue; //for the analog calibration
int maxvalue;
// ------------------------------------------------------------------------------------------------------------------ declarations ------------------------------------------------------------------------------------------------------------------
//******************** define as outputs ********************
        // 46 led controll
      for (int leds = 0; leds < 45; leds++)
      pinMode(led[leds], OUTPUT);
        // two bar led controll
        pinMode (leda, OUTPUT);
        pinMode (ledb, OUTPUT);
        pinMode (simplescan, INPUT);
        pinMode (sensor1, INPUT);
        pinMode (lightenable, INPUT);
        pinMode (motionenable, INPUT);
        pinMode (scan1, INPUT);
        pinMode (scan2, INPUT);
        pinMode (scan3, INPUT);
        pinMode (scan4, INPUT);
        pinMode (scan5, INPUT);
        pinMode (scan6, INPUT);
        pinMode (scan7, INPUT);
        //start the lcd com
} // void setup close
i thought with the above i will be able to control the pins
on the mega
witch will be led[0] to led[45]
but i cant
You should be able to.
but i cant
Why not? What evidence do you have that there is a problem? What is the problem?
it makes high only the leda and ledb pins
while running on that
  displayMessage("Patterns");
  scrollMessage(02,8,"Knight rider 2008");
      int i;
      int j;
  displayMessage("i j");
  delay (2000);
  delay (2000);
      while ( (simplescan = HIGH ) && (scan1 = HIGH) )
  displayMessage("while");
  delay (2000);
  displayMessage("for");
  delay (2000);
       delay (speedtime);
  displayMessage("leds");
  delay (2000);
       delay (speedtime);
       delay (speedtime);
the last msg that i see on screen is "for"
and then stays there
The middle clause in a for statement is a while clause. The body of the loop is executed while (and only when) the middle clause is true.
You want the middle clause to be i<=45;
yes i was thinking with the basic for
stillnot works
  digitalWrite (led[45],HIGH);
  delay(5000);
  delay (2000);
time = 1000;
 if (simplescan = HIGH )
   if (scan1 = HIGH) kitt2008scan (time);
   if (scan2 = HIGH) knight_rider_two_thousand (time);
   if (scan3 = HIGH) four_groups_blink_twice (time);
   if (scan4 = HIGH) bar_blink_twice (time);
   if (scan5 = HIGH) bars_blink_twice (time);
   if (scan6 = HIGH) all_high ();
   if (scan7 = HIGH) kitt2008scan (time);
  if (sensorenable = HIGH )
  if (lightenable = HIGH )
  if (motionenable = HIGH )
i put a led on pin 9 on the mega
but it never lights up
int leda = 12;
int ledb = 13;
 int scan2 = (9+54);
int k;
long rndb;
int maxvalue;
        // 46 led controll
        //start the lcd com
// ------------------------------------------------------------------------------------------------------------------ programm running ------------------------------------------------------------------------------------------------------------------
  delay (2000);
also i have left the pins
analoginput 0,1,2,3,8,9,10,11,12,13,14
unconnected and the arduino takes them as HIGH
i also connect them to the ground and also takes them as HIGH
= is an assignment operator. == is the equality operator.
To compare simplescan to HIGH, use the == operator.
if (simplescan [glow]==[/glow] HIGH )
 if (simplescan == HIGH )
   if (scan1 == HIGH) kitt2008scan (time);
   if (scan2 == HIGH) knight_rider_two_thousand (time);
   if (scan3 == HIGH) four_groups_blink_twice (time);
   if (scan4 == HIGH) bar_blink_twice (time);
   if (scan5 == HIGH) bars_blink_twice (time);
   if (scan6 == HIGH) all_high ();
   if (scan7 == HIGH) kitt2008scan (time);
but it never goes into the if i have conect the analog 0 and analog 8 with the 5v
 int scan2 = (9+54);
does this working to the arduino mega
the 54+pin
i found one more mistake
if (digitalRead(scan2)== HIGH ) digitalWrite (ledPin,HIGH);
if the digitalread of the button in HIGH
http://www.youtube.com/watch?v=PGVv9TrGBeo
This was my first test with arduino and my project
i dont have all the equipment yet
i am still waititng the leds and the transistors
the project will totaly have 92 channels
46 in each bar
it would be able to work as an vu meter also
a temperature meter
i light meter
a motion detector
i found some t10 led in the garage and i couldnt wait the led to test it
this was the leds from channel 8 to channel 22
so the paterns are not show corectly
the speed is controlled by a rotary switch but i dont have it yet
the patterns are also controlled by a rotary switch
the usb cable was only for power not data
http://www.youtube.com/watch?v=d3RwY2-AjxE
vu meter with a pc microphone
http://www.youtube.com/watch?v=p4KCEE3yFWg
and
http://www.youtube.com/watch?v=3mdG6pUF-1o
