Hi all,
I have a problem with a code that I found on a youtube comment sectionLink to the video . Since I'm new with working on Arduino and also have a different Arduino than the one showen on the video, I finally managed to get each motor starting and spining with their own button and potentiometer as I wanted. However the first motor is keep rolling the other direction every 3 seconds. I'm thinking it migh be a problem in the code. Anyone else have had the same problem?
const int controlPin2 = 12; //
const int enablePin = 3; //
const int directionSwitchPin = 9; // connected to the switch for direction
const int onOffSwitchStateSwitchPin = 5; // connected to the switch for turning the motor on and off
const int potPin = A2; // connected to the potentiometer's output
// create some variables to hold values from your inputs
int onOffSwitchState = 0; // current state of the On/Off switch
int previousOnOffSwitchState = 0; // previous position of the on/off switch
int directionSwitchState = 0; // current state of the direction switch
int previousDirectionSwitchState = 0; // previous state of the direction switch
int motorEnabled = 0; // Turns the motor on/off
int motorSpeed = 0; // speed of the motor
int motorDirection = 1; // current direction of the motor
int mot1; // variable to read the value from the analog pin
int mot2;
const int potPin3 = A0; // analog pin used to connect the potentiometer
const int potPin4 = A1; // analog pin used to connect the potentiometer
const int controlPin4 = 13; //
const int enablePin2 = 11; //
const int directionSwitchPin2 = 8; // connected to the switch for direction
const int onOffSwitchStateSwitchPin2 = 6; // connected to the switch for turning the motor on and off
const int potPin2 = A3; // connected to the potentiometer's output
int onOffSwitchState2 = 0; // current state of the On/Off switch
int previousOnOffSwitchState2 = 0; // previous position of the on/off switch
int directionSwitchState2 = 0; // current state of the direction switch
int previousDirectionSwitchState2 = 0; // previous state of the direction switch
int motorEnabled2 = 0; // Turns the motor on/off
int motorSpeed2 = 0; // speed of the motor
int motorDirection2 = 1; // current direction of the motor
void setup(){
// intialize the inputs and outputs
pinMode(directionSwitchPin, INPUT);
pinMode(onOffSwitchStateSwitchPin, INPUT);
pinMode(controlPin2, OUTPUT);
pinMode(enablePin, OUTPUT);
// pull the enable pin LOW to start
digitalWrite(enablePin, LOW);
pinMode(directionSwitchPin2, INPUT);
pinMode(onOffSwitchStateSwitchPin2, INPUT);
pinMode(controlPin4, OUTPUT);
pinMode(enablePin2, OUTPUT);
digitalWrite(enablePin2, LOW);
void loop(){
// read the value of the on/off switch
onOffSwitchState = digitalRead(onOffSwitchStateSwitchPin);
delay(1);
// read the value of the direction switch
directionSwitchState = digitalRead(directionSwitchPin);
// read the value of the pot and divide by 4 to get
// a value that can be used for PWM
motorSpeed = analogRead(potPin)/4;
// if the on/off button changed state since the last loop()
if(onOffSwitchState != previousOnOffSwitchState){
// change the value of motorEnabled if pressed
if(onOffSwitchState == HIGH){
motorEnabled = !motorEnabled;
// if the direction button changed state since the last loop()
if (directionSwitchState != previousDirectionSwitchState) {
// change the value of motorDirection if pressed
if (directionSwitchState == HIGH) {
motorDirection = !motorDirection;
// change the direction the motor spins by talking
// to the control pins on the H-Bridge
if (motorDirection == 1) {
digitalWrite(controlPin2, LOW);
else {
digitalWrite(controlPin2, HIGH);
// if the motor is supposed to be on
if (motorEnabled == 1) {
// PWM the enable pin to vary the speed
analogWrite(enablePin, motorSpeed);
else { // if the motor is not supposed to be on
//turn the motor off
analogWrite(enablePin, 0);
// save the current On/Offswitch state as the previous
previousDirectionSwitchState = directionSwitchState;
// save the current switch state as the previous
previousOnOffSwitchState = onOffSwitchState;
onOffSwitchState2 = digitalRead(onOffSwitchStateSwitchPin2);
delay(1);
directionSwitchState2 = digitalRead(directionSwitchPin2);
motorSpeed2 = analogRead(potPin2)/4;
if(onOffSwitchState2 != previousOnOffSwitchState2){
if(onOffSwitchState2 == HIGH){
motorEnabled2 = !motorEnabled2;
if (directionSwitchState2 != previousDirectionSwitchState2) {
if (directionSwitchState2 == HIGH) {
motorDirection2 = !motorDirection2;
if (motorDirection2 == 1) {
digitalWrite(controlPin4, LOW);
else {
digitalWrite(controlPin4, HIGH);
if (motorEnabled2 == 1) {
analogWrite(enablePin2, motorSpeed2);
analogWrite(enablePin2, 0);
previousDirectionSwitchState2 = directionSwitchState2;
previousOnOffSwitchState2 = onOffSwitchState2;
mot1 = analogRead(potPin3); // reads the value of the current sensing
mot2 = analogRead(potPin4); // reads the value of the current sensing
Serial.print(" Moter 1 current sensing: ");
Serial.print(mot1);
Serial.print(" Moter 2 current sensing: ");
Serial.println(mot2);
delay(200);
