One on one flashes
Hello
Question. I have a MAX 7219 driving several LEDs. I have two LEDs in parallel with each other on the breadboard. They both work as design both flashing in unison. When I move them apart from each other but still the in parallel to each other one flashes the other stays on. The distance is about 20 feet. I have double check my wiring. I have noticed that the one away from the breadboard does dim when the one on the board is on.
There are limits to cable length.
Are you use SPI.
Having LEDs in parallel without any external resistors is a bad idea, they will not share current equally. Added to that you are running one on the end of a long wire. The rapid changing in signals that is the multiplexing will tend to get "smudged" over a long wire. Basically don't do it, or do it properly with line drivers at both ends, which will be more trouble than it is worth.
Thank you both. After I posted I thought about that. Will let you know.
I'm sorry. I'd said I'll let you know and I never got back to you. Yes it was too long. I shorten to 1 foot and it worked much better. Thanks
