hello forum. i am working on a project, that requires to move 4 servos simultaneously.
i have tested all 4 of my servos, with a servo tester, and they all work just fine.
now, lets say i am using the following code :
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(7); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
witch is exactly the same as the tutorial. i have servos on pin 7,8,A0,A1. when i am testing the pin 7, it works just fine. But if i use pin 8 , or ther others, nothing happens. the servos dont bother moving everywhere. they only move like 5-9 deggres counter-clockwise, when power is first applied… what i might be doing wrong?? thanks!
