One Time password based circuit breaker
I am trying to control a relay with an otp password , GSM module is used to transfer the otp. I have some of the code completed, no compiling errors
new.ino (1.94 KB)
amal11zz:
Instead of attaching your code, try posting it, using [code]code tags[/code].
(Code tags are the <> symbols in the reply window. It’s not too late to edit and do that. :slight_smile: )
You’re much more likely to get a reply. :slight_smile:
(Many of us don’t want to mess around downloading people’s code and creating a folder etc to view it, then cleaning it up afterwards. Much easier to view in your original post. :wink: )
Edit: By “OTP”, do you mean one-time-programmable, or do you have another meaning for this abbreviation?
Edit2: It’s also a good idea to include URLs for the source of any non-standard include files/libraries, such as “GSMSim.h” and “Password.h”. :wink:
#include <Password.h>
#include <Keypad.h>
#include<LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#include <GSMSim.h>
#define BAUD 9600
long randNumber;
GSMSim gsm;
Password password = Password( randNumber);
int relay_pin = 10;
const byte ROWS = 4;
const byte COLS = 4;
// Define the Keymap
char keys[ROWS][COLS] = {
 {'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}
byte rowPins[ROWS] = { 9,8,7,6 };
byte colPins[COLS] = { A0,A1,A2,A3 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  pinMode(relay_pin, OUTPUT);
 lcd.begin(16,2);
 lcd.print(" Design project");
 lcd.setCursor(0,1);
 lcd.print(" circuit breaker");
 delay(2000);
 lcd.clear();
 randomSeed(analogRead(0));
randNumber = random(1000,9999);
 Serial.println(randNumber);
 lcd.setCursor(0,1);
 Serial.println("GSMSim Library - SMS Example");
 Serial.println("");
 gsm.start(); // baud default 9600
 //gsm.start(BAUD);
 Serial.println("Changing to text mode.");
 gsm.smsTextMode(true);
 char* number = "+9********";
 char* message = randNumber;
 Serial.println("Sending Message --->");
 Serial.println(gsm.smsSend(number, message));
 delay(2000);
 keypad.addEventListener(keypadEvent);
void loop(){
 keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
 switch (keypad.getState()){
   case PRESSED:
lcd. print("Pressed: ");
lcd.println(eKey);
switch (eKey){
 case '*': checkPassword(); break;
 case '#': password.reset(); break;
 default: password.append(eKey);
void checkPassword(){
 if (password.evaluate()){
  lcd.println("Success");
 }else{
  lcd.println("Wrong");
I imagine that by OPT you "mean one time password". Unless this is an "academic exercise", I would have expected to see two sketches (a) one to generate a one time password (series) and send it to the device with the relay & keyboard (b) to receive the password, store it, wait for a user to attempt to enter the password and then operate the relay (if successful).
