One wire digital temperature sensor read EPPROM
what output do you see with this code? (serial monitor at 115200 bauds)
#include <OneWire.h>
const byte ONE_WIRE_BUS = 10;       // Pin connected to 1-Wire bus, add a 4.7K resistor as per datasheet
const byte EEPROM_READ_CMD = 0xF0;  // Command to read from EEPROM
OneWire onewire(ONE_WIRE_BUS);
  byte data[32]; // Array to store EEPROM data
  byte addr[8]; // Array to store sensor address
  // Search for 1-Wire devices on the bus
  if (!onewire.search(addr)) {
    Serial.println("No more addresses.");
    Serial.println();
    onewire.reset_search();
    delay(250);
    return;
  // Print the address of the detected sensor
  Serial.print("Sensor Address: ");
  for (byte i = 0; i < 8; i++) {
    Serial.print(addr[i], HEX);
    Serial.print(" ");
  Serial.println();
  // Reset the OneWire bus and select the sensor
  onewire.reset();
  onewire.select(addr);
  // Send command to read EEPROM data
  onewire.write(EEPROM_READ_CMD);
  // Read data from EEPROM (32 bytes)
  Serial.print("EEPROM Data: ");
  for (byte i = 0; i < 32; i++) {
    data[i] = onewire.read();
    Serial.print(data[i], HEX);
    Serial.print(" ");
  Serial.println();
void loop() {}
