1.
In the above, there is no mention of the starting address of EEPROM from which data read to begin!
2.
You may try the following untested sketch which attempts to put (0x12, 0x23, 0x34, 0x45, 0x56, 0x67, 0x78, 0x89) into MAX31286's EEPROM stattinng at location 0x00. The sketch reads back the data and shows them on Serial Monitor. Please, report the result. (I have no device/sensor to test.)
(1) Make the following connections:
UNO MAX31286
5V VDD (Pin-1)
GND GND (Pin-4), AD0-AD3 (Pin-5 to 8)
DPin-10 DQ (Pin-2)
Pin-3 is open
(2) Upload the following sketch in Arduino UNO (Compiled not tested)
#include<OneWire.h>
OneWire ds(10);
byte romCode[8]; //64-bit (8-byte daddress)
byte recData[128];
byte eepromData[] =
//---- get device address
ds.reset();
ds.search(romCode);
//----Write 8-byte data in Scratchpad 2 ((EE)---
ds.reset();
ds.select(romCode);
ds.write(0x0F); //Scratchpad 2 write command
ds.write(0x00); //target EEPROM address (Page-0)
ds.write_bytes(eepromData, 8);
//--- copy Scratchpad 2 data into EEPROM
ds.write(0x55); //copy command
ds.write(0xA5); //programming enable command
delay(25); //max write time delay tWR = 25 ms
//---reading EEPROM-----
ds.write(0xF0); //EEPROM read command
ds.write(0x00); //address of ist location of EEPROM
ds.read_bytes(recData, 128); //all 128 bytes are raed
//---- display first 8 locations---
for(int i = 0; i < 7; i++)
Serial.print(recData[i], HEX);
Serial.print(' ');
ds.reset(); //bring device in idle mode
void loop() {}
(3) Press RESET Button of Arduino UNO
(4) The Serial Monitor should show:
12 23 34 45 56 67 78 89
