onebutton library combined with sleep mode on attiny85
I'm using power saving functions and onebutton library together
My issue is that I can wake my attiny85 from sleep with a double click but not a button hold.
Can anyone shade light on this for me?
EDIT: So i changed the click times and this now works, but can anyone still explain it? This has stumped me for a while.
#include <OneButton.h>
#include <avr/sleep.h>    // Sleep Modes
#include <avr/power.h>    // Power management
#include <avr/wdt.h>      // Watchdog timer
//int emitter = 0;
int starterDelay = 1450; //1392 time between the starter signal being send and the actual data signal
int interPulsedelay = 20; //delay between the data pulses milliseconds
unsigned long int sleepTimer = 0;
int scoreIncrease = 0;
boolean clickFound = false;
int deepSleep = 0;
OneButton button(2, false);
ISR (PCINT0_vect)
 // do something interesting here
  resetWatchdog ();
 //PORTB = 0;
  pinMode(0, OUTPUT);
  button.attachDoubleClick(doubleClick);
  button.attachPress(held);
  button.setClickTicks(300);
  button.setPressTicks(800);
   DDRB =  0b00000011;		// set PB1 (= OCR1A) to be an output
   setFrequency(38000);
  PCMSK  |= bit (PCINT2);  // want pin D4 / pin 3
  GIFR   |= bit (PCIF);    // clear any outstanding interrupts
  GIMSK  |= bit (PCIE);    // enable pin change interrupts
  button.tick();
     //sleepModeA();
  sleepTimer++;
  if(sleepTimer > 24000)
   sleepTimer = 0;
   //deepSleep++;
   //clickFound = false;
   sleepModeA();
void doubleClick()
  int bubs = random(0,7);
   if(bubs > 3)
      for (int x = 0; x < 3; x++)
      three();
      delay(interPulsedelay);
      four();
  //checker light
   for(int a =0; a < 6;)
    digitalWrite(0, HIGH);
  delay(50);
  digitalWrite(0,LOW);
  delay(50);
  a++;
  clickFound = true;
  sleepTimer = 0;
void held()
   if(bubs > 3)
      nine();
      ten();
  //checker light
  for(int a =0; a < 3;)
  delay(100);
  delay(100);
  a++;
  clickFound = true;
  sleepTimer = 0;
ISR (WDT_vect)
   wdt_disable();  // disable watchdog
}  // end of WDT_vect
void resetWatchdog ()
  // clear various "reset" flags
  MCUSR = 0;
  // allow changes, disable reset, clear existing interrupt
  WDTCR = bit (WDCE) | bit (WDE) | bit (WDIF);
  // set interrupt mode and an interval (WDE must be changed from 1 to 0 here)
  WDTCR = bit (WDIE) | bit (WDP3) | bit (WDP0);    // set WDIE, and 8 seconds delay
  // pat the dog
  wdt_reset();
  }  // end of resetWatchdog
void sleepModeA ()
    oneOgma();
  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
  ADCSRA = 0;            // turn off ADC
  power_all_disable ();  // power off ADC, Timer 0 and 1, serial interface
  noInterrupts ();       // timed sequence coming up
  resetWatchdog ();      // get watchdog ready
  sleep_enable ();       // ready to sleep
  interrupts ();         // interrupts are required now
  sleep_cpu ();          // sleep
  sleep_disable ();      // precaution
  power_all_enable ();   // power everything back on
  }  // end of sleepModeA
Thanks, GMcG
Hi,gmcglinn
you solved this problem? If yes, how?
