Hello All,
Using the onebutton library how do you turn OFF an led with a long-press button press, of 2.5 seconds and then turn ON the led with another long-press of 2.5 seconds using the same button.
Thanks for any help
Hello All,
Thanks for any help
Hello
What have you tried ?
You don't need a library to do that.
Hi Blackfin,
I know that I am all set with doing that without a library, I just started playing with the onebutton library and was wondering how to do it with the library.
I was just hoping I could get a code snippet from someone.
I have tried attachDuringLongPress, attachLongPressStop I can turn off a led with a long press but I can't figure how to turn it back on with a long press. I did all this without library but just curious about doing it with onebutton library.
I just need a small code snippet from someone
I want button 5 to do the job on the long press
Here is my code using the library where I can blink the LED's with a long-press and stop blinking the less with a long-press stop.
I want to turn them all off and keep them off with a 2.5 second long press, then with another long-press 2.5 seconds turn them back on.
//Declarations
////blh64 Faraday https://wokwi.com/arduino/projects/323950857541386835
#include "OneButton.h"
// Setup a new OneButton push buttons on pin 4 and 5
OneButton button_blink_the_fog_lights(4, true); //original
OneButton switch_turn_on_the_high_beam_fog_lights(5, true);
//define
#define DISABLED false
#define ENABLED true
#define LEDon HIGH
#define LEDoff LOW
unsigned long currentMillis;
unsigned long previousMillis;
const unsigned long blinkInterval = 100;
//LED's
const int fog_light_low_beam = 6;
const int fog_light_low_beam_indicator = 7;
const int fog_light_high_beam = 8;
const int fog_light_high_beam_indicator = 9;
//bool
bool blinking = DISABLED;
bool just_blink_the_low_beams = DISABLED;
bool blink_both_the_low_beams_and_the_high_beams = DISABLED;
bool foglightsareoff = DISABLED;
//enum { LIGHTS_OFF, LIGHTS_LOW_BEAM, LIGHTS_HIGH_BEAM, LIGHTS_BOTH };//original
enum {LIGHTS_LOW_BEAM, LIGHTS_BOTH};//my add edit
//lightState works with enum
int lightState;
//END Declarations
//setup
pinMode(fog_light_low_beam, OUTPUT);
pinMode(fog_light_low_beam_indicator, OUTPUT);
pinMode(fog_light_high_beam, OUTPUT);
pinMode(fog_light_high_beam_indicator, OUTPUT);
//digitalWrite(fog_light_high_beam, LEDoff);
//digitalWrite(fog_light_high_beam_indicator, LEDoff);
digitalWrite(fog_light_low_beam, LEDon); //my edit or add
digitalWrite(fog_light_low_beam_indicator, LEDon);//my edit or add
//this lightstate fires off first
lightState = LIGHTS_BOTH;
// Setup the Serial port. see http://arduino.cc/en/Serial/IfSerial
while (!Serial)
; // wait for serial port to connect. Needed for Leonardo only
//button_blink_the_fog_lights.attachClick(start_the_blink_short_click);//original
button_blink_the_fog_lights.attachDuringLongPress(start_the_blink_short_click);
button_blink_the_fog_lights.attachLongPressStop(stop_the_blinking);
switch_turn_on_the_high_beam_fog_lights.attachClick(turn_on_the_high_beam_fog_lights);
//switch_turn_on_the_high_beam_fog_lights.attachDuringLongPress(turn_off_all_the_fog_lights);
//switch_turn_on_the_high_beam_fog_lights.setPressTicks(2500);
//setClickTicks(int)
//bool isLongPressed()
//int getPressedTicks()
}//setup
//loop
//don't forget to set the start time with millis()
currentMillis = millis();
// keep watching the push buttons:
button_blink_the_fog_lights.tick();
switch_turn_on_the_high_beam_fog_lights.tick();
if ( blinking ) {
blink_the_fog_lights();
}//loop
void turn_on_the_high_beam_fog_lights()
Serial.println("switch_turn_on_the_high_beam_fog_lights click.");
switch (lightState)
case LIGHTS_LOW_BEAM: // low beam fog lights are on so switch to just high beam fog lights
//digitalWrite(fog_light_high_beam, LEDon);// original
//digitalWrite(fog_light_high_beam_indicator, LEDon);// original
just_blink_the_low_beams = ENABLED;
Serial.println("high ON");
case LIGHTS_BOTH: // both low and high beam fog lights are on so switch everthing off
lightState = LIGHTS_LOW_BEAM;
blink_both_the_low_beams_and_the_high_beams = ENABLED;
Serial.println("all OFF");
}// switch (lightState
}//turn_on_the_high_beam_fog_lights
void start_the_blink_short_click()
blinking = !blinking;
if ( blinking == DISABLED )
blinking = ENABLED;
}//if
}//start_the_blink_short_click
void blink_the_fog_lights()
//if ( lightState == LIGHTS_OFF ) {
// lights are off so nothing to do
// return;
if (currentMillis - previousMillis >= blinkInterval)
// enough time passed yet?
previousMillis = currentMillis; // sets the time we wait "from"
//if the value of "lightState" equals the value of "LIGHTS_HIGH_BEAM" "OR" the value of "lightState" equals the value of "LIGHTS_BOTH"
if (blink_both_the_low_beams_and_the_high_beams)//all the fog lights are on
// toggle high beams
digitalWrite(fog_light_high_beam, !digitalRead(fog_light_high_beam)); // shortcut to toggle the LED
digitalWrite(fog_light_high_beam_indicator, !digitalRead(fog_light_high_beam_indicator)); // shortcut to toggle the LED
digitalWrite(fog_light_low_beam, !digitalRead(fog_light_low_beam)); // shortcut to toggle the LED
digitalWrite(fog_light_low_beam_indicator, !digitalRead(fog_light_low_beam_indicator)); // shortcut to toggle the LED
else//just the low beams are on
}//if else
}//if
}//blink_the_fog_lights
void stop_the_blinking()
blinking = DISABLED;//stop the blinking
//leave on or off the proper fog lights when the blinking stops
}//if else
}//stop_the_blinking
I got the long-press working but why does millis() not work but delay(2500) does work?
here is the script
// 01.03.2014 created by Matthias Hertel
// ... and working.
/* Sample output:
Starting TwoButtons...
Button 1 click.
Button 2 click.
Button 1 doubleclick.
Button 2 doubleclick.
Button 1 longPress start
Button 1 longPress...
Button 1 longPress stop
Button 2 longPress start
Button 2 longPress...
Button 2 longPress stop
// Setup a new OneButton on pin A1.
OneButton button1(5, true);
//define
#define LEDon HIGH
#define LEDoff LOW
int Long_Switch_Press_Time = 2500; //2.5 seconds
bool first_long_press_happened = DISABLED;
// setup code here, to run once:
while (!Serial) {
// link the button 1 functions.
button1.attachClick(click1);
button1.attachDoubleClick(doubleclick1);
button1.attachLongPressStart(longPressStart1);
button1.attachLongPressStop(longPressStop1);
button1.attachDuringLongPress(longPress1);
button1.setDebounceTicks(50);
} // setup
// main code here, to run repeatedly:
button1.tick();
//timeStart_1 = millis();
// You can implement other code in here or just wait a while
delay(10);
} // loop
// ----- button 1 callback functions
// This function will be called when the button1 was pressed 1 time (and no 2. button press followed).
void click1() {
Serial.println("Button 1 click.");
} // click1
// This function will be called when the button1 was pressed 2 times in a short timeframe.
void doubleclick1() {
Serial.println("Button 1 doubleclick.");
} // doubleclick1
// This function will be called once, when the button1 is pressed for a long time.
void longPressStart1()
//currentMillis = millis(); // better to store in variable, for less jitter
// if (currentMillis - previousMillis >= 5000)
delay(2500);
Serial.println("Button 1 longPress start");
// longPressStart1
if (!first_long_press_happened)
first_long_press_happened = ENABLED;
else if (first_long_press_happened)
}//longPressStart1
// This function will be called often, while the button1 is pressed for a long time.
void longPress1()
Serial.println("Button 1 longPress...");
digitalWrite(fog_light_low_beam, LEDoff); //my edit or add
Serial.println("first_long_press_happened led is OFF");
Serial.println(first_long_press_happened);
else if (!first_long_press_happened)
Serial.println("first_long_press_happened led is ON");
} // longPress1
// This function will be called once, when the button1 is released after beeing pressed for a long time.
void longPressStop1()
Serial.println("Button 1 longPress stop");
} // longPressStop1
//end
Now millis() wont work in a onebutton library function longPressStart1 but delay(2500); works
Here is an example : t961293.ino - Wokwi Arduino and ESP32 Simulator
I see it now switch_turn_on_the_high_beam_fog_lights.setPressTicks(2500); // a long press will be detected after 2500 ms thank you but now another problem
Also after I do a long press my button switch_turn_on_the_high_beam_fog_lights stays at "LOW" ,sometimes, and I have to press it twice to turn on an led, then it is fine, how can I set it to high after a long press?
SUMMARY:
Ok this script works, switch_turn_on_the_high_beam_fog_lights.setPressTicks(2500); // a long press will be detected after 2500 ms, lets me avoid using millis, or delay(2500); Now the only issue is after a long press to turn off all the fog lights, then another long press to turn them back on, the button 5 stays low sometimes, and I have to press it twice to toggle on the high beams from off to on. I have to find out how to set a button to high in the "onebutton library" If the high beams are on and then I do a long-press to turn off all the fog lights, and then I do another long-press to turn the fog lights back on, I then have to do 2 clicks to turn on the high beam fog light because the button is set at low.
Thanks
//Declarations
//define
#define LEDon HIGH
#define LEDoff LOW
int buttonState = 0;
//LED's
//bool
bool the_first_time_long_press_happened = DISABLED;
//bool blinkState = DISABLED;
//bool First_Long_Press = ENABLED;
//bool First_Short_Press = ENABLED;
//bool Do_Not_Run_First_Short_Press_Flag = DISABLED;
bool the_high_beam_fog_lights_are_on = DISABLED;
bool All_The_Fog_Lights_Are_Off = DISABLED;
bool high_beam_pin_flag = DISABLED;
bool second_long_press_dont_turn_on_the_high_beam_fog_lights = DISABLED;
int lightState;
//END Declarations
//setup
while (!Serial)
switch_turn_on_the_high_beam_fog_lights.attachLongPressStart(longPressStart1);
switch_turn_on_the_high_beam_fog_lights.attachDuringLongPress(longPress1);
}//setup
//loop
if ( blinking ) {
}//loop
if (!All_The_Fog_Lights_Are_Off)
switch (lightState)
blinking = ENABLED;
}//if
// return;
}//if else
}//if
}//All_The_Fog_Lights_Are_Off
}//if else
// longPressStart1
if (!the_first_time_long_press_happened)//the LED is on by default so turn it OFF in Button 1 longPress1
the_first_time_long_press_happened = ENABLED;// now make it true so now the LED will be turned OFF
else if (the_first_time_long_press_happened)//the LED is off now so turn it ON in Button 1 longPress1
the_first_time_long_press_happened = DISABLED; //now make it false so now the LED will be turned ON
void longPress1()
if (the_first_time_long_press_happened)//if true turn OFF the LED
digitalWrite(fog_light_low_beam_indicator, LEDoff);
All_The_Fog_Lights_Are_Off = ENABLED;
Serial.println("the_first_time_long_press_happened the LED was ON Now turn off the LED");
Serial.println("the_first_time_long_press_happened is now TRUE - 1");
Serial.println(the_first_time_long_press_happened);
else if (!the_first_time_long_press_happened)//if false turn ON the LED
Serial.println("the_first_time_long_press_happened the LED was OFF Now turn ON the LED");
Serial.println("the_first_time_long_press_happened is now FALSE - 0");
