OneButton Library in wrapper Class
Hi there, hope everyone’s doing well!
This is my first post here, so a tiny bit of context: I’m a .NET developer, mainly C#, having fun on weekends with some hardware!
I’m using a D1 mini and ended up trying to use a OneButton object (from the OneButton awesome Library) as a private member of a custom class, and got into trouble, I believe this is my lack of knowledge of the language itself.
I’m struggling with the attachClick method and its relationships to callbackFunction or static methods alongside modifying a private member of my custom class.
For troubleshooting purposes I’ve created a cutdown project that shows problems.
So considering the following class header:
#include <OneButton.h>
#ifndef Thing_h
#define Thing_h
class Thing
public:
  Thing(int btnPin);
  void setup();
  void tick();
private:
  OneButton _btn;
  int _btnPin;
  bool _state;
#endif
it’s implementation:
#include "Arduino.h"
#include "Thing.h"
// Constructor
Thing::Thing(int btnPin)
    _btnPin = btnPin;
    _state = false;
// Public Methods
void Thing::setup()
    _btn = OneButton(_btnPin, true, true);
    _btn.attachClick([]() {
        _state = !_state;
void Thing::tick()
    _btn.tick();
and the arduino sketch for good measure:
#include "Thing.h"
int btnPin = D2;
Thing thing(btnPin);
  thing.setup();
  thing.tick();
This will throw the following error on compilation:
Thing.cpp:15:9: error: 'this' was not captured for this lambda function
  _state = !_state;
modifying to the following instead:
_btn.attachClick([this]() {
   _state = !_state;
will throw:
sketch\Thing.cpp: In member function 'void Thing::setup()':
Thing.cpp:16:6: error: no matching function for call to 'OneButton::attachClick(Thing::setup()::__lambda0)'
After that I thought I would try another approach as it seems you can pass a static method as an argument to attachClick and so tried the following:
class header:
#ifndef Thing_h
#define Thing_h
class Thing
public:
  Thing(int btnPin);
  void setup();
  void tick();
private:
  OneButton _btn;
  int _btnPin;
  bool _state;
  static void process();
#endif
and implementation:
#include "Thing.h"
// Constructor
    _btnPin = btnPin;
    _state = false;
// Private
void Thing::process()
    _state = !_state;
// Public Methods
void Thing::setup()
    _btn.attachClick(process);
void Thing::tick()
    _btn.tick();
this will throw the following
Thing.h:16:8: error: invalid use of member 'Thing::_state' in static member function
   bool _state;
Thing.cpp:13:5: error: from this location
     _state = !_state;
And so I’m running out of ideas as to what I might be doing wrong.
Am I not following specific programming patterns or trying to do something that is totally possible but taking the wrong approach?
To anyone trying to help out, thank you in advance!
First, I am far, far from your level of expertise. Everything I know of C++ comes from three years of Arduino projects: Halloween and Christmas displays, Escape Room games, and of course IOT.
Plus I read these forums a lot.
Using classes is exceedingly rare here, but if you need multiple instances of an object, then make a library. As I understand, it's essentially the same.
Sorry that I have nothing to add here, but I am interested in the solution you choose and the forum doesn't have a method to "watch" a thread without posting to it.
Hi Steve, thanks for the reply!
I think “expertise” is a bit of a stretch, I’ve started playing with arduino stuff for real something like last month :slight_smile:
I’ll check-out the differences between classes and libraries, thanks for the heads-up, is that something you got a hint for from the error messages or just a common practice?
tguillard:
I followed this morse code library tutorial just to learn how to write a library. Defining a class looks just like a library construction, but I’ve never used a class. (Or namespace).
If you don’t need multiple instances of the object, just keep it simple and write the code as a function. I don’t think there is any advantage to using a class or library for code that is only used once.
I don’t know if it’s common practice but it’s the way I have always coded.
tguillard:
I'll check-out the differences between classes and libraries, thanks for the heads-up
Ignore that advice, it has nothing to do with your issue. Arduino "libraries" are no different than regular C++ code. They just happen to be stored in particular directories that allow them to be included in any sketch.
The problem is that class instance functions have a different signature than regular functions. OneButton's attachClick() function is looking for a pointer to the latter. You can read about it here: Standard C++. Even though you used a Lambda, I guess it's still seen as an instance function.
Static functions have the correct signature and you can use them. However, as you discovered, a static function can't directly access instance data. It needs a pointer to the particular instance whose data you want to access.
Fortunately, the OneButton class has an overload of the attachClick() function that will take a function pointer and a pointer to parameters to send to the callback when it's invoked. Take a look at it in OneButton.h and OneButton.cpp.
gfvalvo:
Try something like this. Compiles but untested:
#include "OneButton.h"
class Thing
  public:
    Thing(uint8_t btnPin);
    void tick();
  private:
    OneButton _btn;
    bool _state;
    static void callBack(void *ptr);
Thing::Thing(uint8_t btnPin) : _btn(btnPin, true, true), _state(false) {
  _btn.attachClick(callBack, this);
void Thing::callBack(void *ptr) {
  Thing *thingPtr = (Thing *)ptr;
  thingPtr->_state = !thingPtr->_state;
void Thing::tick() {
  _btn.tick();
Thing thing(3);
  thing.tick();
gfvalvo, thank you very much for the reply!
I was afraid someone would mention pointers :slight_smile:
I will brush up on the topic and re-open my books, I’ve not done that in a while now, so probably a good idea.
gfvalvo, you were perfectly right!
This compiles just fine and works great on breadboard as well, I just have to adapt to my real thing now (and still brush up on pointers).
Thank you very much for the lift, much appreciated!
tguillard:
Pointers are my Achilles Heel.
Glad you got a solution.
Glad it worked for you. BTW, if the code to process the clicks gets more involved, then the '->' notation required to access instance variables from the static function may become burdensome. In that case, it would be easier to call an instance function from the static function:
class Thing
  public:
    void tick();
  private:
    OneButton _btn;
    bool _state;
    void processClick();
  thingPtr->processClick();
  _btn.tick();
void Thing::processClick() {
  _state = !_state;
Thing thing(3);
  thing.tick();
It would definitely be worthwhile for you to review pointers. IMO, you can't do any serious programming in the language without them. C++ does have references that can do a lot of things that pointers can (and some things pointers can't). But there are times when nothing but a good old-fashioned C pointer will do the job.
