OneButton subfunction
Hello,
I´ve got a problem with the OneButton library and using it with subfunctions.
When pushing a button I like to change a variable in a subfunction.
First problem: The value (dFlow) only gives a “?” back. Maybe there is a problem with the snprintf conversion?
Second:The button is not working, is there a problem using two subfunctions?
// Includes ----------------------------------------------------------------------
#include <OneButton.h>
//oled
#define OLED_RST   8
#define OLED_DC    9
#define OLED_CS   10
#define OLED_DATA 11
#define OLED_CLK  13
#include "SSD1306Ascii.h"
#include "SSD1306AsciiSoftSpi.h"
SSD1306AsciiSoftSpi oled;
// Variables ---------------------------------------------------------------------
// Init up button on pin A1 with default high
OneButton buttonUp(A1, false);
// Current flow value
double dFlow=0;
// Subfunctions ------------------------------------------------------------------
  Increases current flow by 0.1 ml/h
  returns increased flow value
int increaseFlow()
  // Increase flow
  dFlow += 0.1;
  oled.println("2");
  // return new flow value
  return dFlow;
  Attaches ClickHandler to buttonUp
void setButtonUpClickHandler()
  // Attach click handler
  buttonUp.attachClick(increaseFlow);
  Prints on OLED
void print()
  char cFlow[10];
  snprintf(cFlow, 10, "%f", dFlow);
  // Print new flow value
  oled.println(cFlow);
  oled.println("ml/h");
  //oled setup
  oled.begin(&Adafruit128x32, OLED_CS, OLED_DC, OLED_CLK, OLED_DATA, OLED_RST);
  oled.setFont(TimesNewRoman16_bold);
  print();
  Checks cyclic for button interactions
  This function runs in a cyclic loop
  buttonUp.tick();
  delay(10);
int increaseFlow()
  // Increase flow
  dFlow += 0.1;
  oled.println("2");
  return dFlow;
Your function modifies a global float, and returns an int.
Why?
And sprintf doesn't by default support float.
Use dtostrf.
True but doesn´t change a thing, also there was an other mistake in this section:
double increaseFlow()
  // Increase flow
  dFlow += 0.1;
  print();
  return dFlow;
complete:
//oled
#define OLED_RST   8
#define OLED_DC    9
#define OLED_CS   10
#define OLED_CLK  13
double dFlow=0;
  // Increase flow
  dFlow += 0.1;
  print();
  return dFlow;
  Prints on OLED
void print()
  char cFlow[10];
  //oled setup
  print();
  buttonUp.tick();
  delay(10);
What do you mean?
sprintf (and also snprintf) do not support float and the %f template.
  buttonUp.attachClick(increaseFlow);And the returned value goes . . where?
Thank you!!!
Just one more problem. The subfunction is not working correctly do you have any idea?
//oled
#define OLED_RST   8
#define OLED_DC    9
#define OLED_CS   10
#define OLED_CLK  13
double dFlow=0;
  dFlow += 0.1; // Increase flow
  print();
  return dFlow; // return new flow value
//double setButtonUpClickHandler()
//  // Attach click handler
//  return dFlow;
  Prints on OLED
void print()
  char cFlow[10];
  dtostrf( dFlow, 10, 2, cFlow );
  oled.clear();
  //oled setup
  print();
  buttonUp.tick();
  delay(10);
Does the attachClick() function expect a pointer to a function that returns a double? That would seem highly unusual.
Post a link to the OneButton library.
That's the library I'm using:
r8beta:
GitHub - mathertel/OneButton: An Arduino library for using a single button for multiple purpose input.
The library has a function declaration:
 void attachClick(callbackFunction newFunction);
The type of argument is callbackFunction, which is a type defined like so:
 typedef void (*callbackFunction)(void);
What this means is that attachClick takes a pointer to a function that takes no arguments and returns no value.
Why are you insisting on trying to pass it a pointer to a function that is NOT the kind it expects?
what does it mean? what behavior do you see?
When I click the button nothing happens. But wiring is correct, I checked this with the sample code.
Have you changed the function to have the proper signature?
I’ve tried this code
OneButton buttonUp(A1, true);
double dFlow = 0;
void increaseFlow()
  print();
void print()
  char cFlow[10];
  Serial.print(cFlow);
  Serial.println("\tml/h");
  print();
  buttonUp.tick();
  delay(10);
which is derived from yours but does not use the OLED, just the serial console and when I click on the button connected to A1 (I changed to activate the pull-up so the wiring needs to be A1 <–> BUTTON <–> GND) then when I click on the button seems things to work
[sub][color=blue]      0.00	ml/h
      0.10	ml/h
      0.20	ml/h
      0.30	ml/h
      0.40	ml/h
      0.50	ml/h
      0.60	ml/h
      0.70	ml/h
      0.80	ml/h
      0.90	ml/h
      1.00	ml/h
      1.10	ml/h
[/color][/sub]
Notice the string format though… (hint)
Thank you guys! Now it´s working fine!
r8beta:
So, what did you have to change in your code/hardware? The function signature? The wiring?
I did what you and J-M-L said. I made the attachClick Function void.
Also there was an other problem with the dtostrf function. I used the wrong buffer and width size. It now looks like this:
 char cFlow[10];
  dtostrf( dFlow, 8, 2, cFlow );
r8beta:
 char cFlow[10];
good catch, that's what I meant with
Notice the string format though... (hint)
:slight_smile:
Having the wrong signature for the function does just create a warning
warning: invalid conversion from 'double ()()' to 'callbackFunction {aka void ()()}' [-fpermissive]
but that does not prevent the thing to work given how the library uses the call back (does not care about any return value as it's supposed to be void)
