Hello,
My program "drops" one LED from the top of an hourglass into the bottom each minute. After 60 minutes my Seven Segment display will advance its display by one.
All seems to be working well (I have it sped up for testing), but the problem is when the number on the SevSeg changes from 9 to 10, 10 to 11, and 11 to 12. After the change, the ones digit flickers terribly for about 10 seconds. The frequency of the flicker then begins to slow down until the number becomes solid after a total of about 20 seconds.
I have a 220 ohm resistor on pins 1,3,4,6,7,8, and 9 (not using decimal point pin 2). Do I need one on 5 and 10 (Common Cathode) as well?
Any suggestions will be appreciated.
My code is below.
Thank you,
Michael
// FastLED - Version: Latest
Shift register SN74hc595 pin 1 to digital display 9
2 8
3 6
4 7
5 4
6 1
7 not used
8 grnd
9 not used
10 to +5V
11 to arduino 4
12 to arduino 7
13 to grnd
14 not used
15 to digital display 3
16 to +5V
#include <FastLED.h>
#define LED_Pin 2
#define NUM_LEDS 120
CRGB leds[NUM_LEDS];
#define color1 CRGB::Red;
#define color2 CRGB{230, 126, 34};
#define color3 CRGB::Yellow;
#define color4 CRGB::Green;
#define color5 CRGB::Blue;
#define color6 CRGB::Indigo;
#define color7 CRGB::Black;
int HourTen = 0; // ten digit for hours
int HourOne = 1; // one digit for hours
unsigned long prevTime = 0;
unsigned long currentTime = millis();
unsigned int HrInterval = 6000;
unsigned int MinInterval = 1000;
unsigned MinCount = -1;
int y = 0;
int ResetHourglass = 0;
int DATA = 3; // Data Pin (pin 14 on the 74HC595)
int LATCH = 7; // Latch Pin (pin 12 on the 74HC595)
int CLOCK = 4; // Clock Pin (pin 11 on the 74HC595)
int TensDigit = 5; // tens digit for hours (HourTen)
int OnesDigit = 6; // one digit for hours (HourOne)
int Digit[10] = {64, 121, 36, 48, 25, 18, 2, 120, 0, 24};
int DATA = 3;
int LATCH = 7;
int CLOCK = 4;
pinMode(LATCH, OUTPUT);
pinMode(DATA, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(TensDigit, OUTPUT);
pinMode(OnesDigit, OUTPUT);
FastLED.addLeds<WS2812, LED_Pin, GRB>(leds, NUM_LEDS);
FastLED.setBrightness(10);
FastLED.clear();
FastLED.show();
// Initialize all LEDs
for (int x = 0; x < 10; x++) {
leds[x] = CRGB::Red;
leds[x + 10] = CRGB{230, 126, 34};
leds[x + 20] = CRGB::Yellow;
leds[x + 30] = CRGB::Green;
leds[x + 40] = CRGB::Blue;
leds[x + 50] = CRGB::Indigo;
FastLED.show();
//Initializing the Hourglass
for (int x = 60; x < 120; x++) {
leds [x] = CRGB::Black;
FastLED.show();
if (currentTime - prevTime >= MinInterval == true) {
if (MinCount < 59) {
MinCount++;
else {
MinCount = 0;
ResetHourglass = 1;
prevTime = currentTime;
if (ResetHourglass > 0) {
FastLED.show();
ResetHourglass = 0;
HourOne++;
MinDisp();
HrDisp();
void MinDisp() {
leds[60 - MinCount] = CRGB::Black;
y = 9 - MinCount;
if (y >= 0) {
leds[y] = color2;
leds[119 - MinCount] = color1;
FastLED.show();
y = 19 - MinCount;
if (y >= 0) {
leds[y] = color3;
if (MinCount > 9 && MinCount < 20) {
leds[119 - MinCount] = color2;
FastLED.show();
y = 29 - MinCount;
if (y >= 0) {
leds[y] = color4;
if (MinCount > 19 && MinCount < 30) {
leds[119 - MinCount] = color3;
FastLED.show();
y = 39 - MinCount;
if (y >= 0) {
leds[y] = color5;
if (MinCount > 29 && MinCount < 40) {
leds[119 - MinCount] = color4;
FastLED.show();
y = 49 - MinCount;
if (y >= 0) {
leds[y] = color6;
if (MinCount > 39 && MinCount < 50) {
leds[119 - MinCount] = color5;
FastLED.show();
if (MinCount > 49) {
leds[119 - MinCount] = color6;
FastLED.show();
void HrDisp() { //Displays the hour
if (HourOne == 10) { // Reset to 0 after counting for 9 hours.
HourOne = 0;
HourTen = 1;
if (HourTen == 1 and HourOne == 3) { //13:00 becomes 1:00
HourTen = 0; // Resets hours ten digit to 0
HourOne = 1;
digitalWrite(LATCH, LOW);
shiftOut(DATA, CLOCK, MSBFIRST, Digit[HourOne]);
digitalWrite(LATCH, HIGH);
display1();
delay(5);
if (HourTen != 0) {
shiftOut(DATA, CLOCK, MSBFIRST, Digit[HourTen]);
display2();
delay(5);
//End of Void HrDisp()
void display1()
digitalWrite(TensDigit, 1);
digitalWrite(OnesDigit, 0);
void display2()
digitalWrite(TensDigit, 0);
digitalWrite(OnesDigit, 1);
