Onetime-pad in Arduino?
Could you help me run it in Arduino?
#include<iostream>
#include<vector>
#include<stdlib.h>
using namespace std;
void to_upper_case(vector<char>& text, int len)
    for (int i = 0; i < len; i++)
        if (text[i] >= 97 && text[i] <= 122)
            text[i] -= 32;
void print_string(vector<char> text, int len)
        cout << (char) (text[i] + 65);
    cout << endl;
    return;
size_t get_input(vector<char>& msg)
    char a;
    while (1)
        a = getchar();
        if (a == '\n')
        msg.push_back(a);
    return msg.size();
int main()
    vector<char> msg;
    vector<char> enc_msg;
    vector<char> dec_msg;
    int *p;
    int i;
    size_t len;
    cout << "Enter Message to Encrypt:";
    len = get_input(msg);
    to_upper_case(msg, len);
    p = (int*) malloc(msg.size() * sizeof(int));
    for (i = 0; i < len; i++)
        p[i] = rand() % 26;
        if (msg[i] >= 65 && msg[i] <= 90)
            enc_msg.push_back((char) ((msg[i] - 65 + p[i]) % 26));
        else if (msg[i] >= 97 && msg[i] <= 122)
            enc_msg.push_back((char) ((msg[i] - 97 + p[i]) % 26));
            enc_msg.push_back((char) msg[i]);
    cout << "\nEncoded Message:";
    print_string(enc_msg, len);
    cout << "\nKey for decryption:\n";
        cout << (char) (p[i] + 65);
    cout << endl;
    cout << "\nDecrypted Message:";
        if ((enc_msg[i] - p[i]) < 0)
            dec_msg.push_back((char) (enc_msg[i] - p[i] + 26));
        else if ((enc_msg[i] - p[i]) >= 0)
            dec_msg.push_back((char) (enc_msg[i] - p[i]));
            dec_msg.push_back((char) enc_msg[i]);
    print_string(dec_msg, len);
    return 0;
AnIdiot:
And we should do this because...?
I want try how it works and I cannot do it myself, becouse I am newbie. So if you will be so polite and will try to help me. I will be pleased
First of all, your program is written in C++ and most beginners start with C and move to C++ after they understand C. I would suggest you take some simple sample programs from the IDE (e.g., File --> Examples --> 01. Basics --> Blink) and make small changes to it to learn what those changes do. Jumping in with a C++ program may not be the best way to start. Google "Arduino C beginning tutorial" and start reading. I just did that and you'll have about 2.4 million choices.
You are getting compile errors because,
there's currently no support for libstdc++, the standard support library needed for a complete C++ implementation.
