PaoloP
June 21, 2015, 1:07pm
#1
PaoloP
June 21, 2015, 1:15pm
#2
#elif defined(__SAMD21G18A__)
// Arduino Zero
#define PIN_TO_BASEREG(pin) (&(digitalPinToPort(pin)->PIO_PER))
#define PIN_TO_BITMASK(pin) (digitalPinToBitMask(pin))
#define IO_REG_TYPE uint32_t
#define IO_REG_ASM
#define DIRECT_READ(base, mask) (((*((base)+15)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask) ((*((base)+5)) = (mask))
#define DIRECT_MODE_OUTPUT(base, mask) ((*((base)+4)) = (mask))
#define DIRECT_WRITE_LOW(base, mask) ((*((base)+13)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask) ((*((base)+12)) = (mask))
#ifndef PROGMEM
#define PROGMEM
#endif
#ifndef pgm_read_byte
#define pgm_read_byte(addr) (*(const uint8_t *)(addr))
#endif
Penso siano da modificare tutti i define.
Queste sono alcune define nel file variant.h del core della Zero.
#define digitalPinToPort(P) ( &(PORT->Group[g_APinDescription[P].ulPort]) )
#define digitalPinToBitMask(P) ( 1 << g_APinDescription[P].ulPin )
//#define analogInPinToBit(P) ( )
#define portOutputRegister(port) ( &(port->OUT.reg) )
#define portInputRegister(port) ( &(port->IN.reg) )
#define portModeRegister(port) ( &(port->DIR.reg) )
#define digitalPinHasPWM(P) ( g_APinDescription[P].ulPWMChannel != NOT_ON_PWM || g_APinDescription[P].ulTCChannel != NOT_ON_TIMER )
L’indirizzamento interno alle porte ed ai registri è completamente diverso sia dalla UNO che dalla DUE.
PaoloP
June 21, 2015, 1:32pm
#3
I primi due dovrebbero essere:
// Arduino Zero
#define PIN_TO_BASEREG(pin) (portInputRegister(digitalPinToPort(pin)))
#define IO_REG_ASM
Per i modi diretti non ho idea.
Anche perché se si va a vedere il file wiring_digital.c della ZERO
void pinMode( uint32_t ulPin, uint32_t ulMode )
// Handle the case the pin isn't usable as PIO
if ( g_APinDescription[ulPin].ulPinType == PIO_NOT_A_PIN )
return ;
// Set pin mode according to chapter '22.6.3 I/O Pin Configuration'
switch ( ulMode )
case INPUT:
// Set pin to input mode
PORT->Group[g_APinDescription[ulPin].ulPort].PINCFG[g_APinDescription[ulPin].ulPin].reg=(uint8_t)(PORT_PINCFG_INEN) ;
PORT->Group[g_APinDescription[ulPin].ulPort].DIRCLR.reg = (uint32_t)(1<<g_APinDescription[ulPin].ulPin) ;
break ;
case INPUT_PULLUP:
// Set pin to input mode with pull-up resistor enabled
PORT->Group[g_APinDescription[ulPin].ulPort].PINCFG[g_APinDescription[ulPin].ulPin].reg=(uint8_t)(PORT_PINCFG_INEN|PORT_PINCFG_PULLEN) ;
// Enable pull level (cf '22.6.3.2 Input Configuration' and '22.8.7 Data Output Value Set')
PORT->Group[g_APinDescription[ulPin].ulPort].OUTSET.reg = (uint32_t)(1<<g_APinDescription[ulPin].ulPin) ;
break ;
case INPUT_PULLDOWN:
// Set pin to input mode with pull-down resistor enabled
// Enable pull level (cf '22.6.3.2 Input Configuration' and '22.8.6 Data Output Value Clear')
PORT->Group[g_APinDescription[ulPin].ulPort].OUTCLR.reg = (uint32_t)(1<<g_APinDescription[ulPin].ulPin) ;
break ;
case OUTPUT:
// Set pin to output mode
PORT->Group[g_APinDescription[ulPin].ulPort].PINCFG[g_APinDescription[ulPin].ulPin].reg&=~(uint8_t)(PORT_PINCFG_INEN) ;
PORT->Group[g_APinDescription[ulPin].ulPort].DIRSET.reg = (uint32_t)(1<<g_APinDescription[ulPin].ulPin) ;
break ;
default:
// do nothing
break ;
void digitalWrite( uint32_t ulPin, uint32_t ulVal )
return ;
// Enable pull-up resistor
PORT->Group[g_APinDescription[ulPin].ulPort].PINCFG[g_APinDescription[ulPin].ulPin].reg=(uint8_t)(PORT_PINCFG_PULLEN) ;
switch ( ulVal )
case LOW:
PORT->Group[g_APinDescription[ulPin].ulPort].OUTCLR.reg = (1ul << g_APinDescription[ulPin].ulPin) ;
break ;
case HIGH:
PORT->Group[g_APinDescription[ulPin].ulPort].OUTSET.reg = (1ul << g_APinDescription[ulPin].ulPin) ;
break ;
default:
break ;
return ;
int digitalRead( uint32_t ulPin )
return LOW ;
if ( (PORT->Group[g_APinDescription[ulPin].ulPort].IN.reg & (1ul << g_APinDescription[ulPin].ulPin)) != 0 )
return HIGH ;
return LOW ;
Non è così semplice come il core AVR.
Non parlo italiano , ma provato i tempi qui (non ancora approvata da Paul Stoffregen! ) Non una bella esecuzione ma funziona (Google translate!)
OneWire_with_Zero.zip (16.6 KB)
PaoloP
June 30, 2015, 7:15am
#6
Grazie Marcus.
Ho visto che è stato aggiunto questo codice
#elif defined (__SAMD21G18A__)
#define PIN_TO_BASEREG(pin) &(PORT->Group[g_APinDescription[pin].ulPort])
#define PIN_TO_BITMASK(pin) g_APinDescription[pin].ulPin
#define IO_MASK_TYPE uint8_t
#define IO_REG_TYPE PortGroup
#define IO_REG_ASM
#define DIRECT_READ(base, mask) ( base->IN.reg & (1 << mask) ? 1 : 0 )
#define DIRECT_MODE_INPUT(base, mask) { base->PINCFG[mask].reg = (uint8_t)(PORT_PINCFG_INEN); base->DIRCLR.reg = (1 << mask);}
#define DIRECT_MODE_OUTPUT(base, mask) { base->PINCFG[mask].reg&=~(uint8_t)(PORT_PINCFG_INEN); base->DIRSET.reg = (1 << mask);}
//Works also
//#define DIRECT_MODE_INPUT(base, mask) base->DIRCLR.reg = (1 << mask)
//#define DIRECT_MODE_OUTPUT(base, mask) base->DIRSET.reg = (1 << mask)
#define DIRECT_WRITE_LOW(base, mask) base->OUTCLR.reg = (1 << mask)
#define DIRECT_WRITE_HIGH(base, mask) base->OUTSET.reg = (1 << mask)
#ifndef PROGMEM
#define PROGMEM
#endif
#define pgm_read_byte(addr) (*(const unsigned char *)(addr))
#endif
Appena posso lo provo.
PaoloP
July 1, 2015, 1:38pm
#7
Ok, compila ma il mio DS18B20 è guasto.
In attesa di acquisto....
PaoloP
July 1, 2015, 3:28pm
#8
Intanto comunico che la versione 2.3 della OneWire scaricabile dal library manager contiene un work-around per l'uso di architetture non supportate. Al posto dei registri diretti usa semplicemente pinMode e digitalRead/Write.
Da provare....
PaoloP:
Da provare....
Sì vero solo quando la funzione overdrive è usato sono di lettura digitale / scrittura troppo lentamente.
E sì , la soluzione funziona a Zero.
PaoloP
July 4, 2015, 1:42pm
#10
Eureka!
Don't work on pin 2 and 4. No tested on pin 10, 11, 12, 13 and A0-A6
gpb01
July 4, 2015, 2:38pm
#11
PaoloP:
... su che piedini funziona allora ? ? ? :o
Guglielmo
PaoloP
July 4, 2015, 3:19pm
#12
Funziona sui piedini: 0,1,3,5,6,7,8,9.
Da provare i piedino dal 10 al 13 e gli Ax.
Il perché non vada sul 2 e su 4 è un mistero.
Anche perché uso la digitalWrite e la digitalRead.
PaoloP:
Ha un Arduino Pro Zero di Arduino.org è cablato in modo diverso .
Zero Pro sinistra (arduino.org , ora si chiama M0 Pro), originale Zero destra(arduino.cc)
Consente di visualizzare anche il soggetto qui
