Hello!
I have an Arduino + enc28j60 -based ethernet shield + two DS18B20 sensors connected and I am using the webserver from this page: http://blog.thiseldo.co.uk/?p=344
I am not using the pachube updater as it doesn't work anymore but the sketch also outputs the values in csv format as a normal webserver. Then I use my server to fetch the values with wget on the server and it works fine - but the Onewire library used doesn't support minus degrees, it just outputs the right value but no minus sign. What should be added to get the minus to work?
The onewire library from that sketch looks like this:
* Arduino OneWire functions
#define TEMP_PIN 3
void OneWireReset(int Pin);
void OneWireOutByte(int Pin, byte d);
byte OneWireInByte(int Pin);
// Initialise OneWire
void initOneWire() {
// Temp Pin input
digitalWrite(TEMP_PIN, LOW);
pinMode(TEMP_PIN, INPUT); // sets the digital pin as input (logic 1)
void OneWireReset(int Pin) // reset. Should improve to act as a presence pulse
digitalWrite(Pin, LOW);
pinMode(Pin, OUTPUT); // bring low for 500 us
delayMicroseconds(500);
pinMode(Pin, INPUT);
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
byte n;
for(n=8; n!=0; n--)
if ((d & 0x01) == 1) // test least sig bit
delayMicroseconds(5);
delayMicroseconds(60);
d=d>>1; // now the next bit is in the least sig bit position.
byte OneWireInByte(int Pin) // read byte, least sig byte first
byte d, n, b;
for (n=0; n<8; n++)
b = digitalRead(Pin);
delayMicroseconds(50);
d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
return(d);
// Return temp * 100, need to /100 for main part and % 100 for decimal part
int readOneWireTemp() {
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
int temp;
OneWireReset(TEMP_PIN);
OneWireOutByte(TEMP_PIN, 0xcc);
OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
OneWireOutByte(TEMP_PIN, 0xbe);
LowByte = OneWireInByte(TEMP_PIN);
HighByte = OneWireInByte(TEMP_PIN);
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
return Tc_100;
So as you see there is a " if (SignBit) // negative" place but it is not used after that.
I have found (here: Using a DS18B20 Temperature sensor with an Arduino- ar3ne1tt) another similar code which ends like this:
void loop(){
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.print("\n");
delay(5000); // 5 second delay. Adjust as necessary
byte n;
for(n=8; n!=0; n--)
byte d, n, b;
for (n=0; n<8; n++)
return(d);
That code clearly has code for adding the minus sign but it doesn't work at least directly as it is for the serial port.
And on nuelectronics.com which makes the ethernet shield, I have found this in the webserver temperature example sketch:
void getCurrentTemp(char *temp)
int HighByte, LowByte, TReading, Tc_100, sign, whole, fract;
sign = TReading & 0x8000; // test most sig bit
if (sign) // negative
whole = Tc_100 / 100; // separate off the whole and fractional portions
fract = Tc_100 % 100;
if(sign) temp[0]='-';
else temp[0]='+';
if(whole/100==0)
temp[1] =' ';
temp[1]= whole/100+'0';
temp[2]= (whole-(whole/100)*100)/10 +'0' ;
temp[3]= whole-(whole/10)*10 +'0';
temp[4]='.';
temp[5]=fract/10 +'0';
temp[6]=fract-(fract/10)*10 +'0';
temp[7] = '\0';
But that doesn't either seem to work, I guess as it begins with "void getCurrentTemp(char *temp)" and the same part of the code from the link in the beginning of this post begins with "int readOneWireTemp() {".
I could also use the nuelectronics example code (from http://www.nuelectronics.com/estore/?p=12) but that one shows a "Get Temperature" button on the html page and I would need it to show the value directly so that I can fetch it directly to my server without needing it to press any button on any html page.
So my question would be, how to add the minus degree part to the first code in this post? I am also ready to try a totally different code but this is also working really fine apart from that the minus sign is missing..
